BA5door
Reg: 04-02-13
08-23-23 03:16 PM - Post#2861863
I don't want to change my front wheels to accommodate discs.
I know it's been done but I'd like to know more about the process.
Can someone enlighten me?
Member #409
![Rick_L](https://www.chevytalk.org/fusionbb/images/avatars/0.jpg)
08-23-23 04:20 PM - Post#2861865
In response to BA5door
No way without a lot of engineering and machine work, for a net negative result compared to discs.
BA5door
Reg: 04-02-13
08-24-23 06:16 PM - Post#2861894
In response to Rick_L
Still hoping for a response to my question.
Member #409
08-24-23 09:51 PM - Post#2861899
The biggest problem is that none of the dropped spindles have a boss for the anchor pin that the top end of the brake shoes ride against. It's difficult to provide, and must be strong because that pin provides the reaction force for the brake shoes.
irishsteve
Reg: 08-05-22
01-26-24 09:32 PM - Post#2866341
Cut one coil off your front springs.That will bring you down about 1.5 inches.
55MAS
Loc: North Coast, USA
Reg: 12-19-01
01-27-24 07:44 AM - Post#2866347
In response to irishsteve
Agree with the above post.
5Larry7
"20th Year" Gold Supporting Member
![5Larry7](https://www.chevytalk.org/fusionbb/fbbavatars/av-16513-1491177539.jpg)
Loc: Dallas, TX
Reg: 05-17-04
01-27-24 12:12 PM - Post#2866349
I thought there were disc brake kits out there that would fit stock wheels. Try a Google search.
'57 210, 327, Holley MPFI, 700R4, A/C & more.
'51 Studebaker Starlite coupe, Holley MPFI, 350, 700R4, AC & much more. '96 Replica of a 1950's Teardrop Trailer. |
01-28-24 10:44 AM - Post#2866373
sometimes there isnt enough alignment adjustment when doing that. must check first.
docjns1
![docjns1](https://www.chevytalk.org/fusionbb/fbbavatars/av-300769-1659323337.jpg)
Loc: upstate NY
Reg: 11-12-19
02-06-24 05:16 PM - Post#2866652
In response to bobb
If not looking to lower the front end, just convert to discs, you'll have to investigate disc kits and verify you can run your wheels (original 14"?), if so next issue might be they'll push the wheel outward a bit and could cause interference with fenders when turning. On my '65 I was lucky to find a kit that used my original spindles but did move hub/wheel outward about 1/2" if I remember. Mine also required minimum 15" vs o.e. 14" wheels
Steve
327 / 300 L74
M11 3 on the tree
12 bolt 3.31 open dif |
docjns1
Loc: upstate NY
Reg: 11-12-19
02-06-24 06:29 PM - Post#2866658
In response to docjns1
Sorry all, guess I misunderstood the question here...in the words of Emily Litella.." never mind"
Steve
327 / 300 L74
M11 3 on the tree
