Danchuk
Username Post: Edelbrock Carb To Linkage Advice Please        (Topic#365879)
streets
streets
Loc: Central Illinois
Reg: 05-30-04
07-21-21 07:34 PM - Post#2823657
Bought a new Edelbrock 650cfm carburetor and the 56' Handyman has a accelerator rod (BLUE).
Does anyone know of a bushing kit that fills the hole to get the slop out?
Thanks in Advance
Attachment: IMG_5049.jpg (252.19 KB) 12 View(s)
Bad56Sedan
Bad56Sedan
Loc: Pasadena, Texas
Reg: 04-29-04
07-22-21 12:40 PM - Post#2823698
    In response to streets
The blue rod is backwards, the adjustable end is the carb end,
But you are asking about a bushing for the carb linkage to the gas pedal rod threaded adjustable end.
I'm sure those big places that sell all those performance things has what you need.
But I made my own for '56 gas pedal rod to a Holley.
So turn that blue rod around, find a piece of rubber tubing/ grommet that fits the hole in the carb, then piece of tubing of some sort that will fit over the adjustable end piece, make it fit in the grommet, sand down two washers that fit over the adjustable rod end until a cotter pin will fit in the adjustable rod end.
Makes sense ?
Then turn the throttle return spring around and put it through the hole in the gas pedal arm.
VC56S 2 door Sedan, 41 Years
Bad56Sedan
Bad56Sedan
Reg: 04-29-04
07-22-21 12:47 PM - Post#2823699
    In response to Bad56Sedan
Couple of pics,
Attachment: image.jpg (132.08 KB) 12 View(s)
Attachment: image.jpg (152.48 KB) 10 View(s)
Attachment: image.jpg (148.92 KB) 11 View(s)
streets
streets
Reg: 05-30-04
07-22-21 07:12 PM - Post#2823725
Thanks for the quick reply, good suggestions and great pictures. I tried a few carb vendors for a bushing kit without any luck. A grommet the correct size is the way I'll go.
ronnie496
Reg: 04-25-21
09-24-21 08:36 AM - Post#2827862
Did you try Edelbrock?
WagonCrazy
WagonCrazy
Reg: 06-07-05
09-24-21 10:16 AM - Post#2827867
    In response to ronnie496
maybe this?
https://www.summitracing.com/parts/edl-9141
Travs55
Travs55
Loc: Houston, Texas
Reg: 03-11-05
09-25-21 07:32 AM - Post#2827929
Try ChicagoCarburetor.com
Attachment: 77189F6E-45F0-436A-AFF5-FAEA429D5A35.jpeg (402.58 KB) 7 View(s)
streets
streets
Reg: 05-30-04
09-29-21 08:19 AM - Post#2828254
    In response to Travs55
Yes Sir, I did contact Edelbrock without much success.
Travs55 seems to be the best permanent solution and I will contact Chicago Carburetor for their bushing.
As a temp fix I found this at Autozone. It fit well, snapped into both linkage pieces, but will need to be drilled for a cotter pin insurance.
Thanks again everyone.
Attachment: 20210929_104153.jpg (1.86 MB) 2 View(s)
From Autozone
Execution time: 0.011 seconds.   Total Queries: 14   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:57 AM
