The disc brake adapter bracket that bolts to the new stock spindle does not bolt up "flat" to the spindle. It seems this is a problem. IS it?
Should I shim the gap with washers at the steering arms? I probably need to call cpp but there isn't anything listed as such in their catalog as such.
Thanks.
