Username Post: 36 water pump leak        (Topic#359412)
bowtiefan
bowtiefan
Loc: Vacaville, CA
Reg: 02-19-04
01-08-20 09:10 AM - Post#2783986
The fan shaft out of the water pump on my stock 36 is leaking. I was told to tighten the nut a little until it stops leaking. I did that and now it squeals at idle. So, do I replace the water pump, or is it possible to replace the packing around the shaft, and if so, with what?
thanks, Ken
36, 38 & 39 2dr sedan, 41 coupe, 54 convertible, 56 Nomad, 57 210 2dr sdn, 70 Camaro RS, Corvettes; 57, 61, 65 396 coupe, 67 427 convert, 72 T-top, 88 coupe,91 ZR-1, 07 Z06, 16 Z06, 07 Silverado, 09 BMW 135i vert.
Ray P W
Reg: 09-30-15
01-08-20 09:35 AM - Post#2783989
    In response to bowtiefan
Good morning Ken.
The nut you tightened compresses the packing against the shaft. If the packing is all used up some needs to be added. I've had the same '36 Chevy PU since 1965 and I've never replaced the water pump. To keep it working without leaking I add some packing once in a blue moon, put a few drops of motor oil in the oiler at the front of the water pump, keep grease in the grease cup on the driver's side of the water pump and give the grease cup cap an occasional turn to force in some more grease.
If you'd like to see what that packing material looks like I have some from "back in the day" that, as I recall, is graphite impregnated asbestos made just for this purpose.
If you give me your email address I'll send you a photo of that stuff.
Ray W
Execution time: 0.013 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:30 AM
