Username Post: '37 frame        (Topic#358790)
McCargar
McCargar
Reg: 12-07-11
11-12-19 09:29 AM - Post#2780035
I have a 1937 Master Deluxe 2 Dr Knee action and the frame has been cracked/broken both sides about a foot behind the front axle center line. Is this something common to the ’37-38? Or is it just the hard life this car has endured.
Also I’m unable to get the steering wheel off. Does anyone have any special tricks to get it off?
Wayne
gcrkfrd
gcrkfrd
Loc: Neosho, MO.
Reg: 04-01-18
11-13-19 04:49 PM - Post#2780117
    In response to McCargar
Just be super careful, Chebby steering wheels like to hit people in the face
52 Styleline Fourdoor 62 235 PG
McCargar
McCargar
Reg: 12-07-11
11-14-19 09:19 AM - Post#2780141
    In response to gcrkfrd
So noted. That though had never crossed my mind.
1971BB427
Loc: Portland,Or
Reg: 12-06-09
11-15-19 09:55 AM - Post#2780215
What are you using to try and get the wheel off? I've never had much issue if I use a steering wheel puller. One trick is to tighten the puller down pretty snug, and then give the end of the puller a sharp rap with a hammer.That usually jars the worst stuck wheels loose and then they pull right off.
1969 Suburban 2wd 350
1939 Chevy passenger coupe
1937 Austin gasser 327/TH350
Execution time: 0.157 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:44 AM
