Username Post: 38 Master Deluxe        (Topic#353282)
JimBove
Reg: 10-03-18
10-03-18 10:35 AM - Post#2747786
I'm trying to help a freind who is original ownerof a 38 Chevy coupe with the 6. He just finished rebulding the engine, ran it for maybe 2 - 3 minuted and now has milky oil. Short of improper torque on the head or bad headgasket is there any other way water can get into the oil?
10-03-18 11:28 AM - Post#2747788
    In response to JimBove
Het Jim, glad you made it over from Facebook. Someone should jump in on this is a bit.
10-03-18 11:51 AM - Post#2747791
Did they magnaflux the head?
29-41, 42-48, 49-54 Moderator
blue_63
blue_63
Loc: N Dakota
Reg: 11-06-01
10-03-18 11:56 AM - Post#2747792
I am not sure about that 6 cylinder engine, but in the motors I know about ( 348-409 ) all the headbolts enter into the waterjacket. When putting these engines together, you need to put a sealer on the threads and let it set up at least overnight. Perhaps that is your problem. Plan on buying a new headgasket.
Greg
JimBove
Reg: 10-03-18
10-03-18 04:02 PM - Post#2747803
They had the head sent out and while one should beable to assume that would be part of the rework I probably shouldn't. I've seen dumber stuff. I should ask...it did come back with valve guides that were too long...
JimBove
Reg: 10-03-18
10-03-18 04:03 PM - Post#2747804
    In response to blue_63
It's worth a look. The book they have only gives disassembly directions not reassembly so it's possible.
2blu52
2blu52
Reg: 03-12-02
10-04-18 11:00 AM - Post#2747850
The oil pipe that supplies the rockers runs through the water jacket. My dads 38 buick suffered a failure in that.
THOMAS JEFFERSON
JimBove
Reg: 10-03-18
10-04-18 12:28 PM - Post#2747859
    In response to 2blu52
Re-ALL
Found this website with answers...though I'm not sure all - http://chevy.oldcarmanualproject.com - It answered the question about head bolt sealent - not needed. Still need to check on the magnaflux but it looks like oil tube is the best bet. There seem to be more than one oil line fittings going through the water jacket that should be tightened before adding coolant plus a somewhat lenghty process of tightening the headbolts and setting valves as you go. I'm sure I'll be busy for a couple of days! Thanks for the help!
10-04-18 04:44 PM - Post#2747872
Need to verify the valve to valve guide clearance. The shops that are not familiar with them, set the clearance like the V8's and it is too tight and you can seize a valve.
38TownSd
Loc: Bracebridge Ontario Canad...
Reg: 04-04-13
11-06-18 07:24 AM - Post#2750593
The oil pipe that goes through the coolant in the block has higher internal oil pressure than the coolant. However there is a fitting under the side cover where the pipe exits the block. If the fitting is leaking coolant there, it could easily cause the problem.
Execution time: 0.015 seconds.   Total Queries: 8   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:07 AM
