Username Post: LED Bulbs with Incandescent?        (Topic#360760)
scrambldcj8
scrambldcj8
Loc: Belchertown, MA
Reg: 04-06-03
05-01-20 05:15 PM - Post#2792558
I know with LEDs, a compatible flasher needs to be used due to it thinking a bulb is out (low draw) causing a rapid flash....that is my understanding.
If add an LED at the end of a circuit with incandescent bulbs ahead of the LED will I have any issues. Thanks in advance.
Edit, I am talking about marker/running lights and turn signals.
Edited by scrambldcj8 on 05-01-20 05:21 PM. Reason for edit: No reason given.
05-01-20 06:21 PM - Post#2792567
    In response to scrambldcj8
Bulbs are wired in parallel, not in series, so there is no "ahead" of each other. The flasher depends on the total current draw, so anytime you replace a incandescent with a LED, you lower the current draw (load), so the flasher will not work as designed. Turn signals and emergency flashers are the only ones affected. Running lights and some side markers aren't wired to a flasher.
scrambldcj8
scrambldcj8
Reg: 04-06-03
05-02-20 04:27 AM - Post#2792598
    In response to acardon
  • acardon]so anytime you replace a incandescent with a LED, you lower the current draw (load), so the flasher will not work as designed. quote Said:
OK, but if I have incandescent bulbs still in place will it work alright with a standard flasher?
ie: I am adding an LED into the circuit along with incandescent bulbs. My thinking is the standard flasher might not notice the lower draw of the LED because the incand bulb is still in place at another socket? Thanks for the response!
Senior Moderator
05-02-20 07:09 AM - Post#2792611
When mixing, it's trial and error as to whether everything will behave. Which vehicle are we talking about? In the case of a GMT400 truck, sometimes LED's in the signals will affect an incandescent corner bulb adversely (dim glow full time.)
You don't necessarily need to buy a flasher, or install a resistor. Many of the stock flashers can be easily modified to cancel any hyperflash. However, if you're leaving the main bulbs as incandescent and adding LED's, you most likely won't have any issue with the flasher.
05-02-20 11:57 AM - Post#2792629
    In response to someotherguy
You might not have any problems adding an LED further along the line. But why do you want to cut into the wiring when you can just get a flasher for the LEDs and everything is plug and play?
1957 Cameo Carrier
Senior Moderator
05-02-20 12:18 PM - Post#2792631
    In response to wagonman100
I said nothing about cutting into the wiring?
scrambldcj8
scrambldcj8
Reg: 04-06-03
05-02-20 04:02 PM - Post#2792649
Ah yes, my bad! It's my 1983 Jeep CJ (100% Chevy drivetrain though ).
Have aftermarket Gen-Right fenders which eliminate the OEM side marker/turn signal and in turn uses a stealth lite for that function which is LED. I guess I'll go ahead and give her a go. Like I said, I don't foresee any issue since the incands are still in place on the rest of the Jeep.
Senior Moderator
05-26-20 07:32 AM - Post#2794869
I don't know if your '83 Jeep uses an electronic style flasher or the old thermal can design. If it's electronic, it probably has the same exact timer IC used in the ones our trucks have. In that case if you end up with hyperflash with the LED's installed, you can easily hack the flasher by cutting the lead to a certain pin on that IC. It's easy, and free. Can provide info if you're interested.
Or, if it's got the thermal style and you don't want to change that, you can install resistors - 6 ohm / 50 watt are the typical ones you see with the gold aluminum heat sink on them, and they're really cheap through most sources. Just mount them somewhere that won't be damaged by heat as they do get HOT while in use. Screwed to a sheetmetal inner fender, or a core support, with a little heat sink compound between is ideal.
05-26-20 03:02 PM - Post#2794908
Not you Richard. The original poster asked about adding LED lights and keeping the incandescents in place. That would require splicing into the wiring.
1957 Cameo Carrier
Execution time: 0.012 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:22 AM
