Username Post: turn key-nothing        (Topic#357547)
66cayne
66cayne
Reg: 08-06-08
08-06-19 01:24 PM - Post#2772546
1966 Biscayne. Went to fire her up, turned the key and nothing. No slow turning, no solenoid clicking, just nothing. The battery is fully charged and it started and ran fine yesterday. I pulled the ignition switch out of the dash. It is the original switch. Everything looks good on the contacts and the connector side. Is there any way to test the function of the switch to see if I have current across the contacts. I have a good multimeter. If not the switch the problem must be further back in the starting system.
08-06-19 01:38 PM - Post#2772549
    In response to 66cayne
See other post. Is it in gear?
66cayne
66cayne
Reg: 08-06-08
08-06-19 02:04 PM - Post#2772552
    In response to acardon
its a 4 speed, no neutral safety switch,. I put her in neutral when I start , or push in the clutch if in gear.
Edited by 66cayne on 08-06-19 02:05 PM. Reason for edit: No reason given.
Maxbigblock
Maxbigblock
Loc: Stuart, Florida
Reg: 12-16-01
08-10-19 05:55 AM - Post#2772871
This is probably not it but, check your grounds. Battery to engine block, engine block to body and body to frame. If after that nothing happens, take a hammer and whack the starter body.
Max
I'm originally from the ONCE great city of Flint, Michigan. The birthplace of General Motors, where A C Spark Plug was formed and headquartered, where the first Corvettes were hand built, and where my 1955 Chevy was made.
Execution time: 0.083 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:30 PM
