Willow
Reg: 05-25-12
12-12-19 09:59 PM - Post#2782042
Help Needed Please!!!
2012 Silverado 1500 crew cab 5.3. Was slowing down and skid control light came on dash and said skid control/Stabltrax off? Thought something in central counsel hit the switch located there but no. Everything acting normal but now have warning lights on dash. Checked ABS fuse, it’s Okay. Can’t reset by pushing on/off switch to clear lights.
Get message to check stabletrax system now upon starting truck and dash warning lights stay on??
Question: Is Truck Safe To Drive???
Can I disconnect battery a few minutes and try to reset???
Thanks in advance for any help. With wife seriously ill I just can’t afford a big repair bill. Hopefully truck is safe to drive
12-13-19 04:35 AM - Post#2782053
In response to Willow
Really no quick fix here, you need to have it scanned for abs/stabilitrack codes. Usually when this happens the abs is disabled but the brakes should work OK.
Edited by Shepherd on 12-13-19 04:36 AM. Reason for edit: No reason given.
12-13-19 10:42 PM - Post#2782111
should be safe to drive. get a $50 scanner, its worth it. nowadays gotta scan evting. had a guy come in with a trans problem that was caused by an engine temp sensor.
Willow
Reg: 05-25-12
12-14-19 01:09 PM - Post#2782145
In response to bobb
Thanks for the replies. On my way to get checked out, lights all went out by themselves. My Chevy dealer said probably a "Soft Code" error,don't worry about it. Everything working as it should. Thanks Again.
chevytrucknut61
Loc: Wichita ks
Reg: 09-26-03
01-21-20 05:17 PM - Post#2784838
My 2011 Silverado did the same thing. The brake light switch is bad causing brake lights to stay on. Change the switch and you’ll be fine. Also caused cruise control problems too! Scared the hell out of me, was on the highway when it happened.
Edited by chevytrucknut61 on 01-21-20 05:19 PM. Reason for edit: No reason given.
