Username Post: Halogen sealed beams        (Topic#365885)
iowa65
Loc: Merrill, Iowa
Reg: 12-30-04
07-22-21 05:38 AM - Post#2823673
I am installing a Classic update harness in my 65 impala. I need to replace the headlight bulbs. Can I use Wagner H5006 and H5001 style sealed beam bulbs? Or Sylvania equivalent. I have read that they use more power. Thanks
Mel Foye
Mel Foye
Reg: 09-29-00
07-22-21 02:40 PM - Post#2823704
    In response to iowa65
I favor Wagner.
It Was On Fire When I Laid Down.
07-23-21 08:58 PM - Post#2823789
are the wires big enough for halogens?
monty56
monty56
Reg: 04-26-04
07-24-21 09:01 AM - Post#2823804
    In response to bobb
I used a pair of relays to power mine. Dimmer switch selects relay.
Monty
2001 Chevy Suburban 2500
2009 Saturn Vue w/20's
Monty's 56 Truck
Avatar is my Truck
Mel Foye
Mel Foye
Reg: 09-29-00
07-24-21 11:49 AM - Post#2823814
    In response to monty56
I agree Monty56. He has new wires but still goes through ign., headlight switch and dimmer. Relays avoid the big drag on these three.
Donny
American Auto Wire - Site Sponsor
Loc: Bellmawr, NJ
Reg: 09-11-06
07-25-21 08:18 PM - Post#2823899
Sorry that I'm just now seeing this. Our Classic Update system will handle standard halogens without an issue. the wires are up-sized and the H/L and Dimmer switches will handle a constant load of about 18 amps. From our testing, most 4-bulb halogen sealed beam systems will have a draw of about 12.5-13 amps.
Donny
Execution time: 0.837 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:17 AM
