Username Post: What wires do I connect        (Topic#358301)
Bobs66IMPSS
Loc: Stafford, Va,USA
Reg: 10-08-02
10-03-19 12:28 PM - Post#2777004
Hi Donny,
Purchased wire harness CG59099H for my 327 with factory gauges with HEI distributor. Just replace starter with Hi Torque PowerMAX .What wires on this harness still get connected to starter? purple only?
what post does it connect to? There are 2 large posts, 1 large post for battery cable, 1 large post that had diode connected to it before replacing points distributor with HEI. 3rd connector has small terminal that purple wire could connect to ?? Thanks for your time
Execution time: 0.013 seconds.   Total Queries: 7   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:10 PM
