Username Post: ~1970-1979 GM Bullet connectors used in FI Cars Roughly 2mm but not quite        (Topic#354170)
toro455
toro455
Loc: Western NY
Reg: 06-15-02
12-01-18 10:29 PM - Post#2753049
Hello,
I'm trying to replace a CTS which communicates with the ECU to control fuel enrichment and which commonly goes bad. This rubber molded connector is integral to the sensor assembly. The pins are close to 2mm bullet connectors. However the 2mm bullet female was too small for the original male and the male 2mm fits the original female but it is a little loose.
I was wondering if AAW has any experience with the connector assembly or even the correct bullet connector size. If not did GM perhaps associate these with a name like they did with other connectors which would make search easier?
I'm adding some pictures and sketches. I don't want to destroy my original failed sensor to get better pin measurements so especially for the male I may have underestimated the diameter but only slightly.
These photos are from a 1979 Cadillac Eldorado but the same sensor was used on all GM (at least Cadillac) from around 1970 through 1979.
Thank you,
Scott
Attachment: 1970-1979_GM_Coolant_Temp_Sensor_electrical_plug_for_fuel_injected_cars.JPG (146.42 KB) 74 View(s)
1970-1979 GM Coolant Temp Sensor electrical plug for fuel injected cars
aawtech
Loc: Bellmawr, NJ
Reg: 09-11-06
12-02-18 11:05 PM - Post#2753143
    In response to toro455
  • toro455 Said:
Hello,
Hi Scott,
Thank you,
Scott
Sorry Scott, but we do not have anything like this. Not even sure what it is or what family it might be.
Donny
Edited by aawtech on 12-02-18 11:06 PM. Reason for edit: No reason given.
toro455
toro455
Loc: Western NY
Reg: 06-15-02
12-03-18 05:07 PM - Post#2753241
Ok Thanks for looking. I think possibly if I could find a split barrel bullet it may work better than the type I found but I haven't found any split barrel bullet connectors which are positively identified with a size.
Split barrel meaning that the male is formed from flat stock into a round shape. Not certain of the official name but one like this capture.
Scott
aawtech
Loc: Bellmawr, NJ
Reg: 09-11-06
12-08-18 08:47 PM - Post#2753932
Scott
Scott, these are not what you are seeing in those other connectors. Just an FYI.
Donny
toro455
toro455
Loc: Western NY
Reg: 06-15-02
12-25-18 08:55 PM - Post#2755593
    In response to aawtech
Donny,
I did finally find the proper terminals. They ended-up being 0.084" or 2.13mm. I guess they were still developing the standard when GM designed these terminals. I don't think they caught-on for the automobile industry but they seemed to be more common in office equipment.
If you come across a need for them in other applications let me know and I can offer more details.
Scott
Execution time: 0.019 seconds.   Total Queries: 11   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:50 AM
