Username Post: HWY-22 kit - adapt to '59 Bel Air?        (Topic#330438)
Hobart
Hobart
Loc: Chicago, IL USA
Reg: 11-18-02
11-15-15 07:43 PM - Post#2589144
Hi Donny,
Years ago I bought a Highway 22 kit #500695, with the necessary add-ons to use in my '58 Delray. I never used it, and now I'm considering using it in my '59 Bel Air. Are you able to tell me the additional part numbers I would need to do this?
Also, after all these years the instructions for the kit are lost, is it possible you could mail me another set?
Thanks Donny!
Bill
Chicago Gearheads Car Club / Lynch Mob Racing
'59 Bel Air 2dr sedan
'68 Chevy II Nova
'72 Eldorado ragtop
'80 Z28
aawtech
Loc: Bellmawr, NJ
Reg: 09-11-06
11-15-15 09:08 PM - Post#2589162
    In response to Hobart
  • Hobart Said:
Hi Donny,
Thanks Donny!
They are available right on line. If all the bags are opened, you're gonna have a hard time identifying what is what I'd think. As far as what all else you'll need, there is a ton. The cluster alone will drive you nuts as there are 3 connections at several locations on the Classic Update version. The T/L pigtails are available, but not with the proper colored wires. The ignition switch will not mount in the dash properly, the P/L connections are an issue, there are no H/L bucket harnesses in the HWY 22. You'll need to buy them separately. By the time you buy everything that you'll need, might be better off getting the Classic Update kit. I'll be happy to check everything for you if want, let me know.
Hobart
Hobart
Reg: 11-18-02
11-16-15 06:20 AM - Post#2589213
    In response to aawtech
Thanks Donny. I have a new AAW taillight harness already, so I'll get online and figure out what the other pieces that I need are. My HWY 22 kit is still all in unopened bags, about all I took out of it were the headlight bucket pigtails for the '58. When I get home tonight and can use a computer I'll try to get the other part numbers together.
Thanks.
Hobart
Hobart
Reg: 11-18-02
11-21-17 08:06 PM - Post#2715251
Hi Donny,
A couple of years ago I asked you about this, and now I'm finally in the reassembly-phase of the project, so thought I'd see if you can give me the necessary part numbers I need to order.
All of the bags are still sealed, and I have all of the kit part numbers if you need them. I already have a new AAW #CF80230 rear light harness.
What other info do you need?
Thanks Donny!
Bill
'68 Chevy II Nova
'72 Eldorado ragtop
'80 Z28
aawtech
Loc: Bellmawr, NJ
Reg: 09-11-06
11-29-17 07:09 PM - Post#2716316
  • Hobart Said:
Hi Donny,
Thanks Donny!
Sorry buddy. Not on here as much as I used to be with new responsibilities at work. You'll need mating connectors for any stock harnesses you have so that you can plug into them. Tell what all you have and what you are trying to do. Send me an email to don.bock@americanautowire.com. or contact one of the guys in sales to help you.
Donny
Hobart
Hobart
Reg: 11-18-02
11-30-17 03:31 PM - Post#2716438
No problem Donny, I figured you were busy, I'll put together an email to you.
Thanks!
Execution time: 0.017 seconds.   Total Queries: 9   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:40 AM
