Username Post: Check DAB?        (Topic#96703)
2004maxx
Loc: Phoenix, AZ
Reg: 11-10-03
04-06-05 11:46 AM - Post#666684
I've been getting this error occasionally on my radio. What does it mean?
CHEVSMAN
Loc: NY
Reg: 10-27-04
Re: Check DAB?
04-06-05 12:39 PM - Post#666685
    In response to 2004maxx
Some 04/05 Malibu, Maxx and 05 G6 equipped with XM radio customers will report that IMMEDIATELY after turning on vehicle ignition they receive a CHECK DAB message displayed on radio or that a radio changed to AM band when they had left it on an XM band the previous ignition cycle (and for 2004 Malibu/Maxx the same key fob being used).
New calibration available to correct. If not happening as described above, calibration does not apply and may need further diagnostic.
Ed
e2helper
Reg: 04-03-04
Re: Check DAB?
04-06-05 05:23 PM - Post#666686
    In response to CHEVSMAN
New calibration only available if you have CD Changer Radio, if not they have to replace radio.
2004maxx
Loc: Phoenix, AZ
Reg: 11-10-03
Re: Check DAB?
04-06-05 05:57 PM - Post#666687
    In response to e2helper
Thats my problem! Intermittently, but immediately after starting the car I get the Check DAB message. I don't have the CD Changer, so they're going to have to replace it I guess.
GM-Tech
GM-Tech
Loc: South Florida
Reg: 06-27-03
Re: Check DAB?
04-07-05 04:03 AM - Post#666688
That's what you get for not checking your DAB once in a while.
2004maxx
Loc: Phoenix, AZ
Reg: 11-10-03
Re: Check DAB?
04-07-05 07:14 AM - Post#666689
    In response to GM-Tech
Shoot, I can't find anywhere in the manual on how to check it! Is there a dipstick to pull out in the center console?
KOne
KOne
Loc: Michigan
Reg: 12-17-03
Re: Check DAB?
04-08-05 02:23 AM - Post#666690
No, no, no, it's one of those sealed DABs; there's no dipstick. You'll need to change the DAB fluid every 50,000 miles if your DAB is used under any of these conditions, otherwise your DAB fluid will not need changing:
- Long trips where loud volume is necessary to drown out a child's complaints
- Prolonged exposure to talk radio
- Excessive use of the XM
1993 Saturn SL1 "Squealer" - Donated 2000 Chevy Malibu LS "Cecillia" - Traded 2002 Saturn SC2 "Silver Bullet" - Mine 2005 Chevy Equinox LT FWD "Unnamed" - Wife's
GM-Tech
GM-Tech
Loc: South Florida
Reg: 06-27-03
Re: Check DAB?
04-08-05 04:20 AM - Post#666691
    In response to KOne
And if you do have to change it, just remember, you can't mix the green DAB with the orange DAB or it turns to gel and clogs the whole thing up.
Execution time: 0.209 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:33 AM
