tarps (7)
Username Post: Noisy fuel pump        (Topic#95466)
BigChevy80
BigChevy80
Loc: Gridley, IL
Reg: 12-04-03
03-25-05 04:47 AM - Post#657980
What is it with the 1995-98 Chevy fuel pumps? Both my '98 and the '96 that I used to have were noisy as hell. I can roll all the windows up and drive down the road and STILL hear the pump whining plain as day. Every truck I've seen from these years does it. I've had my '98 for about a month now and I'm SICK of listening to it.
My father-in-law has a 2002 Suburban, a 2002 Silverado and a 2004 Silverado. None of his vehicles have noisy fuel pumps. Is there a different or later-model pump I can put in it that will not make this gawd-awful noise?
1991 Chevrolet C1500
1998 Ford Explorer
"Natural Gas Vern! Kinda like your first wife: hot, fast and cheap!" --Ernest P. Worrell
Anonymous
Re: Noisy fuel pump
03-25-05 05:43 AM - Post#657981
    In response to BigChevy80
my 95 doesn't make any noise. That year is a TBI pump and they were quieter though. 96 up have vortecs.
Boog
Boog
Loc: Central Arkansas
Reg: 04-28-02
Re: Noisy fuel pump
03-27-05 03:21 AM - Post#657982
    In response to
The factory fuel pumps are normally quiet. A stopped up fuel filter will make the pumps somewhat louder.
Most of the loud pumps I've seen are most normally aftermarket pumps. I have one in my 88 right now that is as loud as yours, windows up and driving down the street and still hear it. It is a non AC pump some one else put in. My 97 Burb has a new AC pump in it and it's perfectly quiet.
Boog
69 Chevy step
06 GMC ccsb Z71
00 GMC excab Z71
All GM...'nuff said!
martinez
Loc: Venezuela
Reg: 10-16-04
Re: Noisy fuel pump
03-27-05 01:57 PM - Post#657983
Maybe you have a cheap aftermarket pump... I always used the AC Delco with great results, not noisy at all.
2006 Silverado 1500
acesttz
Loc: Jacksonville, FL
Reg: 11-15-03
Re: Noisy fuel pump
03-27-05 02:46 PM - Post#657984
    In response to martinez
My AC Delco pump raises hell and it only has 10,000 miles on it. What is worse, the dealer will not warranty it for the noise.
BigChevy80
BigChevy80
Loc: Gridley, IL
Reg: 12-04-03
Re: Noisy fuel pump
03-27-05 03:31 PM - Post#657985
I know I am not crazy. EVERY '96-'98 truck I have ever seen does it. My '98 does it, my old '96 did it, my uncle's '97 does it, my friend's '96 does it, my other friend's '98 does it, etc etc etc.
It's not unbearably loud, but it's definately noticeable. It was worse on my '96 because it had a rear slider window.
I just wonder what they did differently on the newer trucks?
1998 Ford Explorer
Re: Noisy fuel pump
03-27-05 03:43 PM - Post#657986
My '96 was VERY loud.. can't hear my '92 or '94 at all while running.
I have a parts-house brand pump in the '92 that I installed (long before I got on CT and read horror stories of using non-GM pumps) and the only time you hear it is if you turn the key on and wait before starting.
Dunno if the pump in the '96 was original or not since I bought the truck with plenty of miles on it, but man it was loud. Ran great though..
Boog
Boog
Reg: 04-28-02
Re: Noisy fuel pump
03-27-05 04:09 PM - Post#657987
It's really only a problem when it no longer makes any noise at all...
Boog
69 Chevy step
06 GMC ccsb Z71
00 GMC excab Z71
Chevytalk Moderator & "3rd Year" Gold Supporting Member
Loc: Montgomery, AL
Reg: 01-15-02
Re: Noisy fuel pump
03-27-05 04:17 PM - Post#657988
    In response to someotherguy
Both my 96 and my 99 have the Vortecs, the 99 was bought with 44,000 on it and it's up to 95,000. The 96 was bought with 60,000 on it and it's up to 115,000. The 99 has had a noisy pump since I bought it, the 96 is much more quiet. Given the mileage on each when we bought the trucks, I suspect but can't be certain that they're original. But look at the mileage each has given me. Noise does not seem to relate to a "good" or "bad" pump and I have no idea why some are noisier than others. It may bother you, but it may also give you years of good service, or depending on current mileage it may have already given years of good service. If it's working good, I'd live with it. They're not all that cheap or easy to replace.
1979 2wd K5 Blazer, 350/TH350
1985 4x4 M1009 K5 Blazer, 6.2/TH400
G35Vortec454
G35Vortec454
Loc: Southern California
Reg: 12-26-04
Re: Noisy fuel pump
03-27-05 04:28 PM - Post#657989
The noise also is attributed to the kind of tank the pump is installed in. Some trucks have a plastic/rubber shield that helps reduce the noise too. It's in the bare metal tanks that makes the loudest sound.
1998 454 Vortec in a 79 Vandura G35 Dually B+ RV, 4L80E, BW4470/2.72-underdrive, ARB switchable 4.10:1 differential locker, 19.5 Rickson wheels, 34-inch 14-ply Bridgestone M724s.
1987 Vandura 3500 5.7 (K) TBI / 700R4, Harbor Workmaster body.
BigChevy80
BigChevy80
Loc: Gridley, IL
Reg: 12-04-03
Re: Noisy fuel pump
03-28-05 03:45 PM - Post#657990
The pumps on the older TBI trucks aren't loud at all. You can't even hear them. It's the later Vortec pumps that are loud. I guess it must have somthing to do with the greater pressures needed for the different type or fuel injection?
I have no doubt that my current fuel pump will give years of service... I just wish I could replace it with one that wasn't so damn LOUD!!
I know how hard they are to replace, as I've done quite a few ow them in the past. And I don't consider it to be THAT big of a job (as long as the fuel tank is almost empty when you drop it).
1998 Ford Explorer
chrisk1500
chrisk1500
Loc: Saskatchewan, Canada
Reg: 10-30-04
Re: Noisy fuel pump
03-28-05 03:55 PM - Post#657991
Yep, an empty tank and air tools as well as a transmission jack makes the job easy. I have got it down to around 1.5 hours from start to finish with a 10 minute beverage break
07.5 DMAX 2500 HD ext cab, 4x4, Edge EVO Race, 4" straight pipe, PPE tie rod sleeves, bushwhacker pocket flares, etc...
06 Escalade
jp233
jp233
Loc: ATL, GA
Reg: 03-15-04
Re: Noisy fuel pump
03-29-05 02:46 AM - Post#657992
    In response to chrisk1500
my 97 is noise as hell...... I can hear it with the windows up idling
i suspect mine's the original but i'd have to call Chevy and find out for sure again, but I dont believe it was ever changed (bought with 63K now 80)
'99 Ford F-250 SuperDuty 7.3L diesel
sold '97 Chevy Tahoe Z71
several Subarus
several bikes
not enough time
HA139
Reg: 07-11-04
Re: Noisy fuel pump
03-29-05 09:59 AM - Post#657993
    In response to jp233
Hello All,
Replaced the fuel pump on my '99 Burb last March with 125,xxx (original fule pump). The old pump was noisy... bought the new one at Auto Zone and replaced it (Fuel filter as well), the new one was very quiet until about 1 month ago. It now has 145,000 on the clock.. replaced the fuel fliter about 2 months ago with an AC Delco filter. Well, after reading BOOG's comment about a clogged filter could make the pump noiseier I replaced it today and it is back to quiet as can be. You guys are great. Thanks much.
Michael
2009 Chevrolet Suburban
2007 Pontiac Grand Prix
Oklahoma City, Oklahoma
quick_16
quick_16
Loc: South Florida
Reg: 12-13-03
Re: Noisy fuel pump
03-29-05 04:37 PM - Post#657994
    In response to HA139
My 1998 C2500 Suburban pump was loud as I rolled it off the dealer lot in 1998. It got very quiet at 143,000 miles, just about the exact same time the engine died. I still say the General was on narcotics when he designed that entire fuel system....
98 C2500 Suburban 05 M&M dual slip 4 link 236" Dragster 70 SS 454 Chevelle
vogelm1
Reg: 07-16-06
Re: Noisy fuel pump
08-25-06 03:55 PM - Post#657995
    In response to quick_16
Earlier this spring my pump died so bought a Car Quest brand and after installation it sounds like popcorn popping inside the tank. Actually I think it's cavitating...does it with a full tank too. Anyone else experience this. It is rather annoying - and sounds like something is rattling apart in there. I've run it for about 9,000 miles now. I'm tempted to replace it just to see if I got a bum pump. What are your thoughts??
Execution time: 0.08 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:50 AM
