Username Post: 2003 Turn Signal/Hazard Problem        (Topic#91977)
Sleepytime
Reg: 07-14-04
02-22-05 10:21 AM - Post#632493
2003 Silverado base model. Recently, when trying to use the left turn signal, the hazard lights come on instead. It doesn't do it all the time, and I can't seem to find a pattern. When it does do it, I can depress the hazard light button a few times quickly, then the signal will work fine. Tried to take it to the dealership, but they could not duplicate. Any others have similar problems or any ideas what to look for. About out of warranty, and would like to get it fixed before I have to pay for it. Thanks in advance.
1999 Tahoe LT 4x4, 5.7, AutoTrac, loaded 2005 Silverado 1500 Extended Cab SB 4x4 5.3 Alum Blk, G80, more to come (traded) Gun control is not about guns, it's about control.
silveradolsz7153
Loc: Lawrence, KS GO JAYHAWKS
Reg: 11-01-03
Re: 2003 Turn Signal/Hazard Problem
02-22-05 10:45 AM - Post#632494
    In response to Sleepytime
Could be a loose ground. But it may also be a bad multifunction switch. Also start the truck and walk around looking for strange behavior from the turn signals. My wifes Trailblazer had a plug left loose when the socket boards were replaced that caused the turn signal to stop flashing with the brakes applied. Without the brakes, it would alternate flash the turn and brake bulbs. With the ignition off, it worked as normal. Hope this helps.
Bill
If you don't like your job, don't go on strike. Just go in every day and do a really half a$$ed job. That's the American way----Homer Simpson
supersporting88
Reg: 07-02-04
02-22-05 04:14 PM - Post#632495
    In response to silveradolsz7153
I had that same problem with my 03 silverado. It happened a few weeks ago when it was really cold. I took it that following monday, but by then it quit doing it. dealer couldn't find anything wrong. Haven't had the problem since, but I am still kinda worried about it.
Sleepytime
Reg: 07-14-04
02-23-05 10:23 AM - Post#632496
    In response to supersporting88
Mine seems to be linked to moisture, at least somewhat. We have had lots of rain here lately, and it seems to do it more when it is wet than it does on the dry days. I have also noticed that if I hit the signal lever quick and hard enough that it goes all the way down, it doesn't seem to do it (as opposed to just holding it in the flash to pass position).
Guess maybe I should just give up and be like every other New Mexican - turn signal, what's that? The only things you have to have functional in a vehicle here are the brakes (at least sort of) and the boom-boom stereo. Wheels that cost more than the car is worth are also highly recommended along with at least sort of functional hydraulics.
dobber
Loc: n.j
Reg: 02-23-05
02-23-05 05:19 PM - Post#632497
Gentleman if you get to the bottom of this dilema with the turn signal/hazard lights please let me know what fixes it.I'm new to this great site I have an 2003 z71 tahoe and i'm having the same problem with the right turn signal,and turning the flashers off and on a couple times clears it up.This is my wifes truck and it doesnt get driven alot and it has been pretty cold here in jersey.Never did this in summer.Once again thanx for allowing me to be a member of this very helpful site.If i figure anything out I will post it.
ChrisG
Reg: 07-26-04
02-28-05 01:13 PM - Post#632498
I was looking on the http://www-odi.nhtsa.dot.gov web site and came across this:
Make : CHEVROLET Model : SILVERADO Year : 2003
Manufacturer : GENERAL MOTORS CORP.
Service Bulletin Num : 01946 Date of Bulletin: JAN 01, 2004
NHTSA Item Number: 10006497
Component: EXTERIOR LIGHTING:HAZARD FLASHING WARNING LIGHTS
Summary:
HAZARD LIGHT FLASHES WHEN TURN SIGNAL APPLIED. *MR
Check to Request Research. Submit below.
Hope this points you in the right direction.
Sleepytime
Reg: 07-14-04
03-01-05 10:23 AM - Post#632499
    In response to ChrisG
Thanks ChrisG, sounds like just the ticket. Does anyone know if there is any more information available on this bulletin? The dealership said they did a TSB search and didn't come up with anything. Any help would be greatly appreciated.
GM-Tech
GM-Tech
Loc: South Florida
Reg: 06-27-03
03-01-05 01:34 PM - Post#632500
They didn't look close enough then, though it's not a TSB, it's what we call a "PI" (preliminary information). The number is PI01946A.
Basically, replace the hazard lamp flasher - P/N 15764135.
nodakbassmaster
nodakbassmaster
Loc: Poorhouse, SD
Reg: 03-14-04
03-02-05 08:22 AM - Post#632501
    In response to GM-Tech
kinda off the subject a little, but is it one flasher for both turn signals? Or does each side have it own?
'09 Silverado 3500HD CC LB D/A LTZ Z71, Mods Annonymous Member #3
Anonymous
03-02-05 12:48 PM - Post#632502
    In response to nodakbassmaster
I had the same thing happen, then stop happening, a couple weeks ago. Looks like a common malady by the number of folks here reporting it. Mine is a 2005 z71, so not fixed by GM yet
dobber
Loc: n.j
Reg: 02-23-05
03-03-05 01:34 PM - Post#632503
    In response to MI Ben
Thanks to everyone here I'll try the emer flasher.My truck is doing it alot at least twice a day.Then hit the flashers once and it's back to normal.
dobber
Loc: n.j
Reg: 02-23-05
03-19-05 11:44 AM - Post#632504
    In response to dobber
hello all,I talked my local chevy dealer into ordering me up one of them there emer flashers without actually seeing the truck doing what i said it was doing.whatta ya know the flasher problem has'nt repeated yet,thanks again for all the help.
Execution time: 0.235 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:00 PM
