"Win $100" Become a Supporting Member Click here find out how! "Win $100"
BigbluebeastAlex Ross (4)57 KevinPauls56Belair (4) john66 (2)gorescue
Nick_nl (3)A White Sport Coupebigbob53cla55ic (3) 56handyman (2)
hbvicYellowSub
sc15pro
Art Morrison.com
Edlebrock July SpecialsMax Chevy.com
Hellwig Products IncClassic ChevyAmerican Auto Wire Performance Rod & Custom
The Car Guy GarageNewGMParts
Ciadella InteriorsGreg's OnlineShowwheelsusa.com
Impala Bob'sBob's Chevy TrucksBob's Chevelle PartsBob's Classic Chevy
"This is the best of the best forum site for classic GM'S!!"
Join the ChevyTalk Mailing List Annual CT West Coast Get Together
Check out the post in SW Forum
Cruisin For a Cure 2010 (9/25)
Username Post: The "official" seat swap thread        (Topic#86476)
Woogeroo
Woogeroo
Loc: chapter 12, paragraph 15
Reg: 05-26-02
01-05-05 04:25 PM - Post#592746
here it is, raw and barely edited... I searched and clicked for the posts on the various posts about seats.
I put the username and then the forum I found the question/statement from cuz I figured I would go poke around other forums as well. Basically, I was doing it for my own research, but I found so much good stuff already, I decided to go ahead & post it.
Here is how it is laid out.
------------- <- this is between totally different posts on another variation of the seat swap question
-- <- this is between posts that are similiar or where taken from the same thread. Such as a question and answer...
All of these tips were found here in chevytalk 60-66 trucks forum, questions and answers from the many, many posters, credit given for question and answer.
Sometimes I took different, yet similiar answers from the same people from as many as 3 or 5 different posts and put them together.
Anyway, it's long and rough, but maybe it'll help some folks...
-W
-----------begin--------- --------
My 92 Silverado bench fit fine witih the tank still in.
It was almost touching but I drove it before the tank removal without wishing I could move it back anymore.
Barn - chevytalk
I have a 60/40 early 90's in mine and it's very comfortable. I used the seats' mounting brackets and only needed some new
mounting holes.
dvalentine - chevytalk
i just bought a set from a 01 chevy a couple weeks ago for my 60 havnt mounted them down yet.yes the center section needs
mods to the mount brakets.they do put you a little closer to the dash.a smaller steering wheel will help.they are perfect for
my size at 5'10".im also in the process of removing the in cab tank,that will also help on mounting the center section.
have a set of 01 seats in my 60,at 5'10" its great with stock diameter steering wheel.guys a little over 6' may be a little
cramped. looks very nice,but need mods to the floor mounts for the center section that i havent gotten too yet
57wagon - chevytalk
"what year full size 90's chevy trucks have the integrated seat belts? - Woogeroo"
'99s to current '05s have them
61StepSide - chevytalk
I have a 60/40 out of a '96 GMC. It doesn't have the intergrated seat belts but it does have a hole with a plastic bezel for
the middle seat belt.
chevytrucknut - chevy talk
I bought seats made by Steel Horse for '88 to whatever and they fit perfectly in my '66. I had to cut a piece of the mounting
bracket off and drill holes in the floor of the cab to fit. The width is perfect
persh - chevytalk
hey guys what trucks/vans/cars make good donors for a nice custom look 60/40 or 40/20/40 for a 1966 truck thanks
ZZ430trk
90's Dodge truck seats, 1994 and up that is.
Chevy1966pu
I saw a 66 at a car show that had leather buckets from a 96 z71 that look really hot. They even used the center console.
Krzcwby
I put 89 F--d Lariot bench seat in mine.It has a nice pull down arm rest built in.Mine is red to match the interior.The seat
is soft and comfy.
chevytrucknut61
hey trucknut, how did the bolt holes line up for that F**d seat?
jtruck
I had to build stands to bolt on the floor to mount it. Of course the hole didn't match but the front mount curves down like
the floor pan.
chevytrucknut61
I got a becnh out of the mid 70's chevy half ton. It is wicked comfy and bolted right on in...
lowrolledc-10
bucket seats:
hey guys i have a quick question i have a 1966 truck with the original bench seat i want to upgrade the seat to a nice
cruisable bucket seats or captian's chairs, where to find them?; which cars/trucks/vans make good donors? what did you do to
mount them? any tips will help thanx
ZZ430trk
I found a set of buckets out of a 2000 Chevy pickup. I was lucky, the guy was going to put them in a '68 chevy p/u but ended
up wrecking it. I found mine on craigslist.org. They are very comfy, I had do to some fabricating to make them fit, and the
plus is they have the shoulder belts built in. Others have used split bench. If you do a search under "bench seat" or "bucket
seat" you will find a ton of info.
Knuckle_bustin'
I used seats out of a Chevy mini van in my panel. The height is great. And their very comfortable bucket style seats with
armrest.
krylonkid
I've been wondering what was the front seat in the suburbans? I know on the panels they were bucket seats, was the burbs the
same?
Chevyboy62
The burbs had a 60/40 bench. The passenger side was the 40. It flipped forward, seat bottom and all, to allow access to the
rear. AND, that seat was also in panel trucks.
dvalentine
I'd say more of a 70/30. Just ask my wife on a long trip!
gmc63burban
'94-'99 60/40 chevy seat
Do any of you have these, and how hard were they to adapt to your cab? Right now I still have an inside gas tank, But I plan
on moving it. It might not be before I get the seats though. I have a friend with a '96 Z-71 who is giving me his seats.
SilverStreak
I have a '96 60/40 bench. It works fine with the tank. The hardest thing to mounting the seat is the 4 extra holes and making
a spacer for thebrackets to sit on. The floor hump is higher on the newer trucks so the brackets need spacer under them. I just stacked fender washers. Works great.
chevytrucknut
Mine is from a '92 Silverado. (Mounting sounds different than Nut's '96 though.)
Drilled two holes. Tank is still in the cab.
Barn
I just snagged a set of these on ebay. I had heard they would fit so just decided to get them. I have the buckets in my '99
Tahoe and they're so comfortable I wanted the same for the '64. I got the 60/40 bench with drivers side power. Not too bad.
swierker
About those 60/40 seats you guys are installing
Are they with the tank inside the cab or out. Right now my tank is still inside but I want a 60/40
slingblade
i got bucket/bench from a 68(i don't know if it's similar to what you want,) but i got the tank inside and its not too bad
1960stepside
I put a 40/60 split in from a '93 Chev pickup and left the original tank with no problems at all. Just needed a couple of
extra bolts for the other tracks. It has been the best update so far in my truxk. Just like they were made for the earlier
cabs.
GMDad
1965 Chev Pick-up 292 5 spd <- from signature line
if you'll look at where your seat hits the back of the cab,you'll see that the top of the tank is way lower.
zenish
Burb seats:
FYI, there is 2 mounting systems on the burb seats. One is fixed and locks into a hole in the floor. The other system is
movable (like my burb) and attatch to 2 tracks in the floor.
gmc63burban
The '88 and newer GM truck seats are a near bolt-in. Two holes line right up. '92 and newer have built-in headrests.
Chevy1966pu
I used a mid 70's chevy bench and it went in good....the only problem i found (beside drilling the two back holes) was that
is sat a little low for my 6-3" frame, so I sat it on two 2"x2" steel tubes.
I put in a 1977 blazer bench seat and got the upholster kit from LMC Truck. Recovering the seat was probably the single
easiest part of the restoration process.
chadman03
Here are some minivan seats I got cheap. They have storage drawers underneath. They should leave alot of room in the cab.
Shouldn't be too hard to install. Maybe some custom brackets and drilling nothing too hard. Maybe only some shims in the
front or back to get it level. They need upholstery but that should be inexpensive and I'll be able to select whatever color
or pattern that suits me.
tkdtkd
I installed a '92 Chev full size pickup cloth 40/60 split and it went in real easy and it makes one major difference in the
comfort unit of these trucks. Definetly recommend trying to find one.
I used the '92 tracks and drilled the other holes. I like the 60/40 split as I have a 5 spd in mine and the wife is a little
shorter in the legs when she is driving but no problem with the split seat. Gives it the new truck feeling when you are
driving it.
I put a '93 split 60/40 in my 1965 and it went right in with just drilling the extra couple holes for the extra tracks. Works
unbelievably well, especially with the floor shift. It has to be one of the easiest and best modifications for our truck.
GMdad
I am with GMDad on this one. I only know of the '88-'98 seats fitting easily. Two bolts line up, and only the other two need
drilling. I will get a seat from these years. Also, I think it is '92 and up with the headrest upgrade.
Chevy1966pu
The guy I bought my truck from said the seat (and the frame, I think) came out of an '83. All I know is it looks factory.
The frame rails on my seat are 5 1/2" from floor to bottom of the seat. The seat is 8" thick and there is 6 1/2" from the
seat to the bottom of my stock steering wheel.
66 Longbed Stepside
longbedder
what kind of brackets were used to install 94 model 60/40 seat in 1963 chev?
ironbutt_lcmc
I got a '64 with a '92 bench and didn't need to do anything but drill the two rear holes. Don't know if that helps ya or not!
Barn
Do these 88's and up seats just bold in the existing holes?
raven316
Front holes line up,rear must be drilled.
64fleetside
--- end ---
bobschevytrucks.com
bobschevytrucks.com
Woogeroo
Woogeroo
Reg: 05-26-02
Re: summary of seat swap q&a in this forum
01-06-05 04:17 PM - Post#592747
    In response to Woogeroo
--- 67-72chevytrucks.com - 60-66 trucks message board seat search results ----
99-05 tahoe, suburban, yukon, silverado seats work great, and they also have built in seatbelts for us pre 66' people. In street trucks mag they have project old school, and they did a seat search for 60-66 trucks, 99-05 chevy seats placed #1, and 88-98 chevy seats second.
DroppedChoppedPanel
BADPANL
I gave a buddy a wrecked 1989 1 ton crew cab awhile back after he did a lot of rust repair for me. He took the rear seat and it fit perfectly in his 1965 C10. I believe he said all holes lined up.
Yukon Jack
Mechanically Challenged
Rich 5150 69
Rich 5150 69
Loc: Sac, Calif
Reg: 11-21-04
01-06-05 05:44 PM - Post#592748
Thanks Woogeroo, i`ll be in the market for one soon myself, the one I have in there now is cheap foam filled seat, with fold down center jump seat/console, the cheap foam fogs up my windows inside every three days from the formayldihide gasses the foam gives off, plus the frame on the seat back drivers side broke, very thin tube steel. Rich
`64 Chevy sb, `69 RS/SS, `37 F**d Coupe 406 sm blk
http://photobucket.com/R51506964
Renegade
Renegade
Loc: SoCal - OC
Reg: 10-28-02
01-09-05 05:25 PM - Post#592749
    In response to Rich 5150 69
Thanks for the 411. It helps for sure! I'm now on the hunt for the "new" seat set up for the crew cab. Thanks Again!!
Renegade, O.C. SoCal 1964 C20 Crew Cab, Long Bed, Small window - not for long :-). Pics now posted! www.grumpyzgarage.com
sixty5short
sixty5short
Loc: NC
Reg: 05-20-02
01-10-05 07:25 AM - Post#592750
Thanks Woo, I'm printing this out right now. This will come in handy one day when I do the swap.
-Doug
my outdated website
jtruck
jtruck
Loc: Ocean Park, Washington
Reg: 08-26-03
01-10-05 03:53 PM - Post#592751
That's a great service Woog! I was gonna do that 99 or newer seat.
Woogeroo
Woogeroo
Reg: 05-26-02
03-14-05 06:13 PM - Post#592752
    In response to jtruck
jasonrmorrow :
I'm 6'1" and i fit very well with my 79 c10 bench and tank removed.
Woogeroo
Woogeroo
Reg: 05-26-02
05-07-05 12:05 AM - Post#592753
57wagon wrote:
got 01 seats in my 60, gas tank behind seat,but is only causing problems with bolting in the center section of the seat,but i am installing a rear tank as we speak so i can get the center section to work.the outer seat will work ok with in cab tank or not, as the seat mounted seatbelt bolster will hit the back of the cab before it hits the tank it will move you a little closer to the steering wheel ,me being 5'10" i dont have a problem ,a smaller diameter wheel can help also.
GySgtBigdaddy
GySgtBigdaddy
Loc: Hathcock Range Complex, S...
Reg: 02-18-05
05-07-05 05:27 AM - Post#592754
Thanks for the modiavation to go change mine....THE RIGHT WAY? Since you took the extra step and gave us all the skinny on mounting seats properly, I figure I'd take the time to tell ya'll my story and how NOT TO DO IT !
I have a nice bench seat out of a 77 Suburban. I had to drill the front holes on the downward slope of the floorpan and drill the rear holes..no big deal. It sat right in but the hump hit the bottom rail of the bench so I cut out the seat rail section. Then my dumb*@* drilled the holes, put the seat in and it was way too low!! Anyone would've, I don't know, TEST FIT THE SEAT, COMPLETELY, BEFORE DRILLING!! Not me though. I like drilling holes all in my floorboard. I never thought to check the height So I pulled it out and reinstalled my original one. Which is actually in great shape but the vinyl is sorta uncomfortable and its alittle "springy". Now I'm remodiavated to put the 77 bench seat in and the RIGHT way! I guess Im looking to put a piece of steel running from the front to the rear holes to raise it. I'm worried about the slope though. We'll see.
It's GOD's job to forgive bin Laden...
IT'S OUR JOB TO ARRANGE THE MEETING!
SEMPER FI!
USMC
*84 Chevy C20 (Newest Project)
*05 D%$*E 1500 (Daily Driver)
KSever
KSever
Loc: Dodgeville, Wisconsin
Reg: 01-11-04
05-07-05 12:33 PM - Post#592755
    In response to GySgtBigdaddy
Hey Gunny,
I took a seat out of a 76 C-10 and had the same problem your having. I took the seat mount off the old bench seat that was originally in my 63 C-10 and mounted the whole seat mount on the 76 C-10 seat. I did have to do a little cutting on the mount to make it fit the newer seat but it's amazing what a welder can do and make it look like original, and have that cadillac ride.
If you were closer you could have this bench seat I put in the 63 since I'm going to put New bucket seats in the 63 that I got on Ebay for $51 a set.
hilandr451
5th Year Gold Supporting Member and Moderator
hilandr451
Loc: Vacaville, Ca.
Reg: 01-02-02
05-07-05 04:04 PM - Post#592756
    In response to KSever
I'm gonna re-stuff & put one of those $170.00 after market 2 tone seat covers on my stock '66 seat. (LMC, Chevy Duty, etc.)The springs are still good and its a lot softer than the after market one I bought off of my neighbor to tide me over. I'll take pics & post the "how to" on my picturetrail site.
....have hog rings will travel!
Check out the post in the SW regional forum
GySgtBigdaddy
GySgtBigdaddy
Reg: 02-18-05
05-07-05 04:53 PM - Post#592757
    In response to hilandr451
Whats it cost to re-stuff/re-cover my original one if the springs are good? My original seat is actually really clean and with some redoing it would be fine with me. It looks new but needs firmer foam. Maybe thinking of having that shaped foam put in so it forms to ya' and having it covered in grey cloth.
KSEVER , what up with those buckets?!! That sounds better to me than any of these ideas. What year/vehicle did they come from? Let me know how they go in cuz maybe I'll just hold off on everything and do something like that! Buckets would actually be cool with me because it aint like more than two people are going to be riding with me at one time anyway.
SEMPER FI!
USMC
hilandr451
hilandr451
Loc: Vacaville, Ca.
Reg: 01-02-02
05-08-05 01:35 PM - Post#592758
Quote:
Whats it cost to re-stuff/re-cover my original one if the springs are good? It looks new but needs firmer foam. Maybe thinking of having that shaped foam put in so it forms to ya' and having it covered in grey cloth.
You can find that foam at any upholstery shop & I'm checking to see if I can find it anywhere else cheaper. All you need to shape it is an electric meat carving knife and a sander. They do other tricks with other tools (heat guns, hot wire cutters & glue) on door panels & such, but if you're just doing a bench seat I figure "how hard could that be?" the cost of the covers is about $170.00 and you might need to buy a pair of hog ring pliers.
raven
Junior Contributor
raven
Loc: Athens, GA US
Reg: 04-12-01
06-02-05 03:57 PM - Post#592759
I'm going to the Super Chevy Show this weekend and I want to check out the swap meet.
I have a question about this:
Are these seat going to just bolt right in my 66 Fleetside? Somewhere back in this forum I think someone said the front bolts pattern is the same but he back take drilling? I like the idea of the shoulder belts but I also like the Highlander's idea.
My Photos
57wagon
Loc: stony creek va.
Reg: 08-10-02
06-02-05 04:42 PM - Post#592760
    In response to raven
raven316
you will have to drill all eight holes for the 99 up seats.and also some reinforcement of the floor pans to hold the seats in place in case of a accident,since the belts are in the seats.the floor mounts on the center section have to be relocated 4 inches further back to mount in the same holes as the seats inner tracks. i had to set the tracks back farther so they would sit on the floor in the correct place.the tank will interfer with the fold down back of the center section,only if you want to fold it down.
i get off on 57 chevys,i get off on screamin guitars.and a 60 chevy p/u. http://community.webshots.com/user/57210man
raven
Junior Contributor
raven
Loc: Athens, GA US
Reg: 04-12-01
06-03-05 12:16 AM - Post#592761
    In response to 57wagon
Thanks, I think I'll go with plan B!
My Photos
raven
Junior Contributor
raven
Loc: Athens, GA US
Reg: 04-12-01
06-04-05 10:36 AM - Post#592762
Well, what a wake up call that was! I went to the Atlanta Super Chevy Show thinking I could find some seats cheap. It's plan B for sure.
My Photos
dperkins915
dperkins915
Loc: El Paso, TX
Reg: 04-29-05
06-04-05 01:53 PM - Post#592763
Anyone have some good pics of swaped seats in trucks. Im trying to get an idea of which way i want to go with looks and style.
66C20TX
66C20TX
Loc: Fort Worth, TX
Reg: 09-03-04
Just when you give up looking......
06-20-05 01:58 PM - Post#592764
    In response to dperkins915
So I have been looking for a new seat, with the shoulder harness (99-05 model) for about a year, with no luck. I found some here and there but always the wrong color or way too much, so I put the ol' 66 back in. Then I am driving home the rural way to avoid idiots and sitting in a driveway was a bench with the rear for an extended cab with a for sale sign, I stopped eventhough I was broke and asked how much. The lady said $150! great so there is the perfect seat and I have 10 days til payday. She said she'd wait for me to come back and we put them back in her garage, so here is a pic of them sitting in my garage today (payday)! Cannot wait to swap out the old bench! Any advice on the plate I would need for safety?
---Mike
dvalentine
dvalentine
Loc: Sacramento, CA
Reg: 06-22-00
Re: Just when you give up looking......
06-20-05 02:09 PM - Post#592765
    In response to 66C20TX
Juliano's Seat and Belt anchors. These will NOT pull through the floor sheetmetal.
http://www.julianos.com/anchor_plate.html
DVal
Woogeroo
Woogeroo
Reg: 05-26-02
06-20-05 11:08 PM - Post#592766
    In response to dvalentine
I bought two kits of the Juliano's seat belts for bench seats to put in my truck after reading reviews about them here in the forums. I have not installed them yet, but everything looks very strong.
-W
66C20TX
66C20TX
Loc: Fort Worth, TX
Reg: 09-03-04
06-21-05 07:35 PM - Post#592767
Awesome! I am going to order 2 pair for the rear bolts. The middle part does not fit in the same spots as the seats, so I am going to have to make 4 holes for that part, It would fit perfectly if the gas tank was not in the cab not enough money or time to tackle that project. I did see LMC had a gas tank that mounts under the bed.
--Mike
Woogeroo
Woogeroo
Reg: 05-26-02
08-07-06 10:49 PM - Post#592768
The original thread:
New seats almost in !!!!!!!!
#1585911 - 07/29/06 05:40 PM
http://www.chevytalk.org/threads/showflat.php/Cat/0/Number/1585911/an/0/page/0#Post1585911
on persh's idea page:
Add new yukon seat to your pickup or Burb
LT1BURB took seats from a 2004 Yukon and added them to his 196? Suburban.
http://www.persh.org/Pickup/YukonSeats.htm
-W
Woogeroo
Woogeroo
Reg: 05-26-02
12-08-08 06:29 PM - Post#1580558
in this thread here: Seat swaps, started in 12/2008:
tkdtkd wrote the following:
I had installed one Dodge minivan seat and a rat decided to crap on the other one in my garage so tossed them both and did this.
Second row early 90's suburban seat install.
Woogeroo
Woogeroo
Reg: 05-26-02
01-27-09 03:20 AM - Post#1616634
Bigcarman had this thread about his seat swap:
I replaced the tired, worn out seat in my truck with buckets from a 76 stepside.
see the thread for the rest of the details.
-W
Woogeroo
Woogeroo
Reg: 05-26-02
02-15-09 04:52 PM - Post#1630628
more seat talk for our trucks:
Seats for my truck
02-15-09 09:31 AM - Post#1630311
Edited by Woogeroo on 02-15-09 04:52 PM. Reason for edit: No reason given.
Woogeroo
Woogeroo
Reg: 05-26-02
07-24-09 03:58 AM - Post#1740871
The seats are out of a 95 BMW 325I.
Got my seats in, by Yellow63
Edited by Woogeroo on 07-24-09 04:01 AM. Reason for edit: No reason given.
64Guy
64Guy
Loc: MT.Juliet,Tn USA
Reg: 03-17-02
07-24-09 10:14 AM - Post#1741067
Here are a couple of shots of my 98 Tahoe seats in my 64.
Cheers
Attachment: DSC05780.jpg (129.22 KB) 113 View(s)
Attachment: DSC05781.jpg (133.75 KB) 91 View(s)
Everything works if you let it! Travis W. Redfish
Woogeroo
Woogeroo
Reg: 05-26-02
07-25-09 03:00 AM - Post#1741456
    In response to 64Guy
64Guy,
thanks for sharing the shots.
-W
Jac
Jac
Loc: Northern PA
Reg: 04-04-07
07-26-09 07:47 AM - Post#1742074
In my `63 I swapped in a bench from a `91 Dorf. Dirt cheap from pick-a-part and the color works well with the blue truck. Cutting off the front "feet" and welding on some angle iron was all it took to bolt into the OE floor holes.
Shove-ro-lay or Shove-ro-let. Shove it home and let it set.
bobschevytrucks.com
bobschevytrucks.com
Execution time: 0.05 seconds.   Total Queries: 11   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:10 PM
