Username Post: 1997 S10 Blazer Buzzing/Grinding noise under dash        (Topic#77392)
Smurphnet
Reg: 10-09-04
10-09-04 05:01 AM - Post#527006
I have been hearing this buzzing sound coming from behind my dashboard up around where the gas pedal is. It seems to be at it's loudest when I first start the engine and when I rev the engine a bit it goes away, then when the idle comes back down it comes back. I took apart some of the dash to see if I can find the source with no luck, it seems to be coming through the firewall. I can only hear it inside the car but not if I stick my head in the engine compartment. Has anybody seen this before or have any ideas what it could be? Thanks
Matt2.2
Matt2.2
Loc: Seattle, WA
Reg: 11-21-03
Re: 1997 S10 Blazer Buzzing/Grinding noise under d
10-10-04 04:51 AM - Post#527007
    In response to Smurphnet
Mine does something like this too. If you don't rev the engine, but push on the brakes a couple of times does it go away?
Matt
96 S-10 With a 2.2l
Smurphnet
Reg: 10-09-04
10-10-04 07:53 AM - Post#527008
    In response to Matt2.2
It doesn't go away when i press on the brake but the noise changes pitch slightly. I was out there today pressing on the gas pedal with my hand and I could feel a slight vibration in the pedal when I heard the noise but I still can't pinpoint where it is coming from.
Anonymous
10-10-04 07:12 PM - Post#527009
You have turned the heat / A-C fan off I take it??
putting the brakes on would drop the voltage a fraction and the rubbing fan would change tone.
Smurphnet
Reg: 10-09-04
10-11-04 12:13 PM - Post#527010
    In response to UK Texan
No heat or A/C fans on. Even if they are on the noise isn't coming from there. I narrowed it down to it not being anything inside the dashboard, looks like it's coming from behind the firewall by the gas pedal. I give up, I hate to take it to the dealer and get raked over the coals but it is getting louder and more annoying every day.
Smurphnet
Reg: 10-09-04
10-11-04 02:10 PM - Post#527011
Now I'm thinking that it might be coming from the distributor, it's in the exact spot on the other side of the firewall where I hear the noise. I'm going to pull the cap off tomorrow and take a look. It would make sense since the noise changes with engine RPM.
Smurphnet
Reg: 10-09-04
Re: 1997 S10 Blazer Buzzing/Grinding noise under dash
10-12-04 03:07 PM - Post#527012
Boy was I wrong about what the noise was. Turns out the PCV valve was half sticking out and rattling like hell. I couldn't hear it until I got one of those automotive stethoscopes and listened by the valve. Put a new grommet in pushed in the valve and noise is gone, problem fixed.
Execution time: 0.392 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:08 PM
