Username Post: Installing Vent Window rubber and window fuzzies ?        (Topic#61693)
coldmachines
Reg: 06-06-03
03-30-04 10:41 AM - Post#419567
Hello, I just got in my vent window rubber and window channels... but no instructions... I don't think it will be too hard but I was wondering if anyone had a website or suggestions on how to bend these long peices etc... Thanks in adavnce
57tim
57tim
Loc: Cameron, Wi, USA
Reg: 11-09-01
Re: Installing Vent Window rubber and window fuzzi
03-30-04 11:13 AM - Post#419568
    In response to coldmachines
Do a search for window fussies. Its all hand work. Some of us use screws to attach the fuzzies and some use staples.
I think danchuk has a tech section for the vent window rubbers.
You do it different if you have a ht vs a sedan.
57 Bel Air 2dr Ht
327 700r4
chazzerguy
chazzerguy
Loc: NC
Reg: 03-14-03
Re: Installing Vent Window rubber and window fuzzies ?
03-31-04 04:00 AM - Post#419569
One of the Danchuk newsletters last summer had a very extensive article with instructions on how to do window fuzzies. If you drop them an email I'm sure they will be happy to email you a PDF of the newsletter... I wanna say it was published in maybe April or May of 2003...
1957 Bel Air Convertible w/283 PowerPack & PowerGlide (engine code "FC") Matador Red with a white top
Bel_AirAmerica
Loc: Evansville,Ind.U.S.A.
Reg: 05-09-02
03-31-04 04:20 AM - Post#419570
    In response to chazzerguy
A m I correct,there are no fuzzies on the doors of a '55 hdtp?It seems there is a pretty good sized gap between the glass and the interior trim and the stainless,but if that's the way it's supposed to be,so be it.
57tim
57tim
Reg: 11-09-01
03-31-04 04:34 AM - Post#419571
    In response to Bel_AirAmerica
The 57's don't have it on the 2dr ht. I don't know about the 55's but its probably the same.
57 Bel Air 2dr Ht
327 700r4
Rocker
Rocker
Loc: DeSoto,TX
Reg: 01-18-01
03-31-04 04:57 AM - Post#419572
I tried doing mine a couple of years ago and gave up.
I couldn't find any good instructions.
The more instructions I read the more questions I had.
The rubber has to go in a certain direction.
When the rubber was installed in the vent window it was almost impossible to get it closed.
I turned it over to the professionals.
Good luck.
Rocker
1957 Chevy Bel-Air
* 2dr Hardtop
* Matador Red
* 283 4bbl PowerPack
* Powerglide
* Power Windows
* Power steering
* Power brakes
* California bumper
DLM 55
DLM 55
Reg: 06-01-03
03-31-04 12:25 PM - Post#419573
Fur Channel Instructions
The above is a link to the Danchuck article on Fur Channel Installation. I will be tackling the little buggers myself shortly.
http://www.picturetrail.com/gallery/view?p=999&gid=4299724&uid=1251144
67SS427
67SS427
Loc: Lawrenceville, GA, USA
Reg: 05-26-01
03-31-04 02:31 PM - Post#419574
    In response to 57tim
Actually, 57 2 door hardtops(and conv.) do have a felt strip on the inner door garnish molding. The 57 door garnish has an added strip of metal on the vertical side of it for the felt that 55/56's don't have. So 57's have felt on the inside door garnish molding and no felt on the outer stainless. 55/56's don't have felt on either side of the door glass. They use a rubber roller guide on both sides of the glass though. A 57 has a roller guide only on the outside of the glass.
57tim
57tim
Reg: 11-09-01
03-31-04 05:26 PM - Post#419575
    In response to 67SS427
SS427, I stand corrected on the 57 fuzzies. My memory is not getting any better. I just did that job 2 years ago.
57 Bel Air 2dr Ht
327 700r4
Execution time: 0.275 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:33 PM
