Username Post: Removing U Joints with no clips.        (Topic#59507)
RebelLear
Loc: South Carolina
Reg: 03-06-04
03-06-04 05:40 AM - Post#404609
I am trying to remove the U Joints in a 1983 Chevy Truck. The problem is they don't seem to have clips. I have tried to gently tap them out but they won't budge. They have two pin marks on each side of the yoke. Please help. Thanks
LMC Truck
5/7HEAVEN
Old as Dirt Member
5/7HEAVEN
Loc: In a quandry
Reg: 05-27-01
Re: Removing U Joints with no clips.
03-06-04 07:13 AM - Post#404610
    In response to RebelLear
howziit guy!
firstly, welcome to CT club!
secondly, i believe the clips are on the INSIDE, towards the center of the u-joint.
'57 BELAIR sport coupe/383/4-speed
good.wrench
Chevytalk Staff
good.wrench
Loc: new york,usa
Reg: 03-30-01
03-06-04 08:08 AM - Post#404611
ok in this case it's one of two types,one type has clips on the inside as 57heaven told you,the other type has plastic rings inside grooves on the yoke around the u joints,this type you heat the yokes and melt or soften the plastic then press or knock them out.
good.wrench
c/t staff
84 S-1O 4x4 if your poor your crazy,if your rich your eccentric!
SuperSport
Reg: 07-03-01
03-06-04 08:15 AM - Post#404612
    In response to good.wrench
edit(reply deleted)- Oops, nevermind, I mis-read your post
Welcome to CT! ~SS~
Senior Chevytalk Moderator
03-07-04 02:55 PM - Post#404613
I usually have to heat them or beat the snot of of them. Did you get them out? Here is an example of the "inside" clip type.
Destructo
Loc: Lewisville, North Carolin...
Reg: 05-12-03
03-07-04 06:16 PM - Post#404614
If they have never been changed you'll need to heat them up. A lot of time when you heat them up you'll see the plastic come through those little holes, I believe those holes is how they fill the plastic stuff in there. I'v beat them enough to get them out without heating it, but its much easier if you heat them with a torch or something, propane or mapp gas torch should work too.
1985 Chevy K10 Scottsdale SWB 350, 700r4, 10 bolt front, 12 bolt rear. 4" of lift, 33x12.5 M/Ts.
Zeker
Zeker
Loc: New Liskeard ON, Canada
Reg: 12-15-02
03-07-04 06:21 PM - Post#404615
Be careful heating them up, hot grease is inside waiting to burn you. You can even cut them out with a torch but its messy. Heat them, give 'em a shot with a hammer, then use a vice and proper sized socket as a press to press em out. It's always easier beating on them when they are in a vice anyways. For God sakes, if they have clips, take em out before beating or you'll be there for a while.
Never force it, always use a bigger hammer... (that actually applies here)
Zeke
05 2WD 1500HD Crew
99 2WD 4D Tahoe
'87 Harley FLHSS
shark55
shark55
Loc: Paso Robles, Ca.
Reg: 04-16-03
03-12-04 05:03 AM - Post#404616
Your u-joint is held in with a plastic injection by the factory. This is the two pin points that you are referring to. You need to heat this area with a torch. Only heat until the plastic oozes out of the injection areas. Then you can remove the u-joint caps by normal means. You will have to replace the u-joint with the type that has the clips on the inside. When I was a mechanic this is how I did it.
55 2DR Sedan Father & Son Project http://community.webshots.com/user/sharkz55
KShortell
KShortell
Loc: Chesapeake, VA, U.S.A.
Reg: 04-14-01
03-12-04 08:06 AM - Post#404617
    In response to shark55
The factory setup on my truck was the inner C-clips plus the injected nylon. So, don't forget the clips, even with the nylon...
Good luck!
Semper Paratus
FL05-03 Home Page
Stock is not a dirty word...
RebelLear
Loc: South Carolina
Reg: 03-06-04
03-21-04 05:38 AM - Post#404618
Thanks for all the help and advice. Just writitng to say the problem is solved. Had to heat them then press the u joints out. Thanks.
LMC Truck
Execution time: 0.295 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:06 PM
