Username Post: 1988 Chevy Cheyenne 3500 4x4 454 TBI engine specs        (Topic#57277)
9C1guy
Reg: 02-06-03
02-09-04 07:36 PM - Post#389365
Can someone please give me the horsepower, torque, and compression specs on the 454 TBI from a 1988 Chevy truck 3500 4x4. I found this truck in the junkyard and bought the engine out of it. The heads are 3993820 and the block is 14015445. The heads I know are not original, as they came from a 1971-72 Chevy Chevelle or Corvette. The block looks to be the original as installed in the truck. It shows 150K on the odometer, and it looks pretty clean under the valve covers. It has the original TBI intake and throttle body on it as well. Also, I'd like to know what kind of hydraulic flat tappet cam would be good for this engine using these heads and a Performer RPM intake with a 750cfm Q-jet and headers. I'm installing this engine into a 1988 Caprice police car with the 700R-4 trans and a 3.08 rear. Any help would be appreciated. Thanks. carguy26@peoplepc.com
GRUMPYK3500
GRUMPYK3500
Loc: Houston,Tx.
Reg: 04-20-03
Re: 1988 Chevy Cheyenne 3500 4x4 454 TBI engine specs
02-09-04 07:55 PM - Post#389366
    In response to 9C1guy
It's hard to say what the horse power is with different heads on it. but i belive the HP rating was 240 or so for 88.
Link
Trucknut
Trucknut
Loc: Ontario, Canada
Reg: 01-01-01
02-14-04 04:05 AM - Post#389367
    In response to GRUMPYK3500
Here's what I found;
BBC heads: 454 Passenger and Trucks, 113cc chamber, 255/114 ports, 1971-1984
Block:14015445 1978-1990 454, 2 or 4 bolt
88' K3500 HP ratings:
230hp @ 3600rpm
385lb/ft @ 1600rpm
Kris
Zeitler
Zeitler
Loc: Sweden (Europe)
Reg: 06-21-03
02-14-04 03:17 PM - Post#389368
will a th700 really take the torque from that mighty 454?
a huge tranny cooler maybe help..
but it sounds like a cool project
Suburban K10 -87 6 cyl Turbodiesel /Th700 K30 axles 4:56 , 33"
Blazer K5 -88 350/Th700
9C1guy
Reg: 02-06-03
02-17-04 12:33 AM - Post#389369
    In response to Zeitler
I pulled the heads from the 454 over the weekend and I found a .040 bored block with flattops and 2 small valve reliefs. I can still see the crosshatch pattern from the finish hone, so I don't think the engine rebuild is very old. The block is most definitely a 4 bolt block, but the last 6 numbers on the deck surface don't match the last 6 numbers of the VIN from the truck I pulled it from, so who knows what it's out of. Anyway, it's a call to Jeg's with my list and my trusty credit card and we'll be on the road before you know it! Hot Dang!!!
Execution time: 0.336 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:36 PM
