Username Post: CHEVY BOLT PATTERN        (Topic#53695)
RICK`S SS
Loc: United States
Reg: 11-16-03
12-31-03 05:45 AM - Post#364253
WHAT IS THE CORRECT WAY TO MEASURE THE BOLT PATTERN ON A IMPALA 1964. I MEASURED THE STUDS FROM CENTER TO CENTER AND GOT 4 1/2 " BUT I DONT FIND ANY LISTINGS FOR THAT , THEY ARE ALL 4 3/4" WHATS UP.IF IT IS A CHEVY WHEEL WILL IT FIT ANY CHEVY????
THANKS RICH
Ricks`s SS
68 corvette T-Top 4 speed
64 malibu 283 4 speed
wskaiser
Loc: Austin, Tx
Reg: 06-03-03
Re: CHEVY BOLT PATTERN
12-31-03 06:43 AM - Post#364254
    In response to RICK`S SS
Don't measure from center to center. Hook the tape over the outside edge of one stud and then skip one stud and measure to the center of the next stud. Main thing it to have only one stud between the two you are measuring. It seems stupid but that is the way they are measured.
doubleE
doubleE
Loc: Eagan MN
Reg: 06-02-03
12-31-03 10:03 AM - Post#364255
I guess I have to disagree with wskaiser. Maybe that measurment does turn out to be 4 3/4", don't know as I never measured it that way, but...
Its the Bolt Circle Diameter in question. Since there are 5 studs, no two are directly across from each other making it difficult to measure since the diameter is the measurment of a stright line from one side to the other and passes through the center of the circle. Measuring from one stud to any other will not give you the right answer. So you have to imagine a circle that goes through the center (not the outside edge) of each of the 5 studs (or the center of the holes on the wheel) The diameter of this imaginary circle is 4-3/4".
This was the standard bolt circle for full size Chevy passenger cars and most other GM cars for many years. Not sure what bolt circle today's fwd cars use.
Eric
DonSSDD
DonSSDD
Loc: Nova Scotia, Canada
Reg: 08-21-01
12-31-03 10:45 AM - Post#364256
    In response to doubleE
I found out in looking for 15 inch steel wheels that the junkyards here measured them one way which was different from the correct way, which is the way DoubleE says.
My 4 3/4 inch was their 4 1/2 inch. I learned to ask for the "big Chevy car 5 bolt pattern".
What I did was trace the correct bolt pattern on a piece of cardboard and take that with me to get wheels. The 4 1/2 inch backspacing is also an important measurement when you are looking for wheels. THe backspacing will determine how big a tire you can fit in the wheel well, among other things.
Member #2194
chevytruckdude
Loc: Minneapolis, MN
Reg: 09-28-03
12-31-03 11:37 AM - Post#364257
    In response to DonSSDD
1/2 ton 2wd chev and gmc truck and vans also share the same bolt pattern as fullsize gm cars.
1964 Impala SS 383 4spd
1966 Pontiac Lemans 350 700R4
1984 C10 Cheyenne ShrtBx 2wd 350 700R4
1995 Chevy Caprice 9C1/LT1
2001 GMC Sierra SLE Z71 XtendCab ShrtBx 4wd 5.3 4L60E
kcthedog99
kcthedog99
Reg: 09-28-03
12-31-03 12:10 PM - Post#364258
If I remember my geometry correctly and working it out as a geomentry problem, the bolt circle diameter should be 1.7 times the center-to-center distance of any two adjacent studs. The factor of 1.7 ONLY applies to a 5 stud wheel.
Anonymous
12-31-03 01:02 PM - Post#364259
Hey I hate to rain on a parade - but Kaiser is correct.
That is the way many custom wheel mfgs measure bolt circle diameter.
Rich, 1971 was the introduction of the 5" bolt circle on the large car Chevy line (same as the 1/2 ton truck chassis)
So any 5 bolt Chevy wheel prior to 1971 (Chevelle/Monte were still 4.750") will be 4.750" bolt circle.
As mentioned by the other member, the backspacing is critical for clearance with the inner fender/suspension components. Also, if front disc brakes are used, make sure the rim doesn't interfere with the caliper - some can.
RICK`S SS
Loc: United States
Reg: 11-16-03
12-31-03 03:50 PM - Post#364260
    In response to wskaiser
thanks to all that replied,i think i got it now
Ricks`s SS
doubleE
doubleE
Loc: Eagan MN
Reg: 06-02-03
01-01-04 08:27 AM - Post#364261
    In response to
OK - took the tape measure out to the garage to see who's right. First, do we all agree that the bolt circle for pre 71' full size passenger cars is 4.75" (4 3/4")as stated by Chevrolet? Here is what I came up with.
Useing Kaisers method of outside to outside edge of the studs and skipping one, I measured 5". Same method but using the center to center of same studs - 4.5".
Useing the 1.7 method, I measured 2 13/16" center to center of adjacent studs. After doing the math this came to 4.76" (which is close enough for me).
Useing the method I described in my 1st post, I measured 4.75".
So Ollie, If I want to purchase a new set of wheels from an after market source for my 62' Impala, do I ask for 4.5", 4.75", or 5"
62sedan
62sedan
Loc: Above the red Texas dirt
Reg: 08-12-02
01-01-04 08:43 AM - Post#364262
doubleE: Re-read his posting, as you did not measure as how he stated to do so. (see the following)
Chuck
doubleE
doubleE
Loc: Eagan MN
Reg: 06-02-03
01-01-04 10:09 AM - Post#364263
    In response to 62sedan
Sorry, my mistake. Going from the outside of one to the center of the other does come to 4.75" but still seems a little hoky to me. It appears to work in this case but what if you had larger or smaller studs? That would alter this measurement.
Measuring the true diameter of the circle going through the center of the studs / holes works no matter if if its a 4, 5, 6, or 8 hole bolt pattern. DoubleE
threeimpalas
Loc: Central Iowa
Reg: 02-21-02
01-01-04 11:25 AM - Post#364264
    In response to chevytruckdude
Depends on the model years you are talking about.
The 1991-96 fullsize car bolt pattern is 5 x 5", same pattern shared with the half-ton pickups till the current body style trucks. The '71-'76 B-Bodies did have the 5 x 5", but that was do to their ~4,200 lbs curb weight.
The down-sized B-Bodies of '77-'90 had the 5 x 4.75" bolt pattern, shared with other GM rear wheel drive cars. The '77-'90 wagons, police, and taxi cars had the 5 x 5" pattern as part of their HD brake package.
The '77-'90 Cadillacs, Buicks, and Oldsmobiles, that retained the long 121.5" wheel base also retained the 5 x 5" pattern, also having the HD brakes because of their ~4,200lbs.
When the '91-96 B-Body arrived, GM made the 5 x 5" pattern standard, on sedans and wagons, again because of weight, this time ~4,000 lbs.
So, in summary, you'll need to double check the bolt patterns when it comes to the "full size" GM cars.
'58-62s and 348/409s
kcthedog99
kcthedog99
Reg: 09-28-03
01-01-04 01:50 PM - Post#364265
For what it's worth:
Mathmatically speaking, the actual bolt circle diameter can be found using the following factors....
4 bolt pattern - 1.4 times the center-to-center distance between adjacent lug bolts
5 bolt pattern - 1.7 times the center-to-center distance between adjacent lug bolts
6 bolt pattern - 2 times the center-to-center distance between adjacent lug bolts
8 bolt pattern - 2.6 times the center-to-center distance between adjacent lug bolts
The value you get will be approximate since the 1.4, 1.7, 2 and 2.6 factors are rounded-off values of a more precise number. Still, the number you calculate should be very close ... as confirmed above.
Now, that being said, the calculations will measure the actual bolt circle diameter. If the industry measures in a way that specifies the bolt cirlce diameter is something other than the actual all bets are off.
stinger74
Loc: Steelville,MO,USA
Reg: 09-08-02
01-01-04 01:58 PM - Post#364266
    In response to kcthedog99
My......head......hurts.
how much is that chevy in the window? wuff wuff
Bigpat1802
Loc: Lincoln,Nebraska
Reg: 02-02-03
01-01-04 03:20 PM - Post#364267
Kaiser's way is the correct way..if you have 5 bolts...Otherwise if you have more or less you do not use the same method....If you have a Jeg's Catalog..look inside they give you pics and instrunctions on how to check all!
Your 64 Impala has a 5x4 3/4
However my rear on my 64 has a 5x4 1/2...lol (Ford 9" baby)
64 Impala
01-01-04 05:40 PM - Post#364268
    In response to Bigpat1802
Kaiser's method is needed ONLY if you have 5 bolts. If you have any even number you can just measure the bolt circle directly (center to center of any two studs/holes straight across from each other).
poncho62
Loc: Ontario, Canada
Reg: 11-01-03
01-02-04 04:26 AM - Post#364269
GAWD.....it's not rocket science.
5 stud wheel....measure centre to centre across the studs and add 1/4 in.
Anonymous
01-02-04 07:40 AM - Post#364270
    In response to poncho62
From the wheel interchange
To determine bolt circle diameter measure from center of 1 stud hole to center of furthest stud hole skipping 1 stud. Measurement will not be exact and must be converted as follows;
measurement = Bolt circle
3-3/4" = 4"
4-1/4" = 4-1/2"
4-1/2" = 4-3/4"
4-11/16" = 5"
5-3/16" = 5-1/2"
94.3mm (3-11/16") = 100mm
Source - Hollander Wheel Interchange 56th edition
Moopar2ya2
Loc: Calgary, Canada
Reg: 03-15-03
01-02-04 11:03 AM - Post#364271
    In response to
Most wheel places and wreckers have a set of devices that look like plastic measuring spoons with a cone shaped end so they can accurately determine the bolt pattern spacing by measuring the distance and reading off the bolt pattern from the gage. Saves heads from hurting. There are also some after market wheels (mag and steel) that have both patterns. To further confuse things the U.S. Pontiacs have the 5 on 5 while the Canadian ones have what ever the Chev of that size and vintage did.
poncho62
Reg: 11-01-03
01-02-04 04:09 PM - Post#364272
    In response to
3-3/4" = 4"
4-1/4" = 4-1/2"
4-1/2" = 4-3/4"
4-11/16" = 5"
5-3/16" = 5-1/2"
Seems to me, they are adding 1/4 inch................
Anonymous
01-02-04 06:26 PM - Post#364273
I know the bolt pattern to my belair i just want to know what back spacing did the factory stock 1963 belair have? What back spacing would i have to use to put a 15x10 on the back of a belair?
Execution time: 0.369 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:48 AM
