Username Post: 1955 spark plugs        (Topic#38151)
bbqbrisket
bbqbrisket
Loc: nj
Reg: 01-30-03
06-27-03 06:52 AM - Post#256565
I see that the spark plug for a 55 was 44-5. Is that 1 type of plug or two different ones (44 and 45)?
I've got an R-45 in mine...is that correct?
thanks
http://img239.imageshack.us/img239/6238/5chevys2du.jpg
Anonymous
Re: 1955 spark plugs
06-27-03 06:54 AM - Post#256566
    In response to bbqbrisket
You probably mean 44-S, not 44-5.
bbqbrisket
bbqbrisket
Loc: nj
Reg: 01-30-03
06-27-03 07:14 AM - Post#256567
    In response to
Jal,
Nope, unless its a misprint in both chev service manual and chiltons. I do see in the chev service manual one get a get a 43-5 and 46-5 for different uses. But I've been using an R45
and I don't know if thats correct a replacement or what.
bubba
Robert_May
Old as Dirt Member
Loc: San Marcos, CA USA
Reg: 01-03-02
06-27-03 08:11 AM - Post#256568
The R-45 plug is the resistor plug version of what is normally run in your engine. If you are running solid wires then I'd use that plug otherwise, replace them when it is time to do so with the 45 plug in some other variation, I run 45 plugs myself.
Robert May Fat? Eat less and you will get thinner!
Anonymous
06-27-03 08:59 AM - Post#256569
As Robert points out - the use of an AC 45 or R45 is acceptable in your engine bbq.
Jaly, the original plugs were dash numbered.
Wanna set??? Every now and then I come across them.
Personally, I prefer the NGK plug because it is plated and doesn't rust - as the AC's do after a few months.
Anonymous
06-27-03 09:16 AM - Post#256570
    In response to
It's a new one on me (which happens several times a day).
What's "dash-numbered" mean?
bbqbrisket
bbqbrisket
Loc: nj
Reg: 01-30-03
06-27-03 09:22 AM - Post#256571
    In response to
I wanna know what the dash means too.
Anonymous
06-28-03 12:41 AM - Post#256572
    In response to
What I meant by dash numbered is the original plugs were...
44-5
They didn't use the "number" alone as in 44 or 45.
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
06-28-03 02:16 AM - Post#256573
The AC 44-5 spark plugs covered both the 44 and 45 heat ranges.The earlier 216 engine used a 46-5 which was a "hotter" version.There were smooth sided insulator plugs.Chevrolet was one of the only cars that used them (from 1949-1955)In 1956 the ribbed insulator plugs were factory installed and the conventional 44 or 45 or 46 plugs were used.Eventually the 44-5 plugs were discontinued and the 45 etc. became the replacement.The R or resistor plug is the modern replacement.I have used those for years in my cars with the resistance wires with no problem.The AC plugs with the entended tip have a number that ends in an S.These are of no advantage today but were introduced back when leaded gas caused lead deposits to form of the spark plug tips.This would cause a high speed miss.The longer tip was used to burn off the deposits due to being in the hotter combustion area.If a car was used for city driving and using leaded gas it would develope a bad high speed miss and replacing the plugs was the only cure.I used to replace the plugs every 2000 miles on my "57.This is one of the great advantages of todays unleaded gas.
bbqbrisket
bbqbrisket
Loc: nj
Reg: 01-30-03
06-28-03 02:43 AM - Post#256574
    In response to Gene_Schneider
gene,
that indeed is a complete answer. That fully answers the question thanks...
What causes plugs to continually foul??
06-28-03 03:11 AM - Post#256575
Gene, a very good answer, but I must disgree with you on one small point. The extended tip plugs are just as useful today as in the past, and they do the same thing now as then.
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
06-28-03 07:55 AM - Post#256576
    In response to Rick_L
The advantage of the extended tip plugs can be a matter of opinion.I don't mean that they are bad-just not necessary under normal conditions.I would say best for an engine that is operated at low speeds most of the time.When I had my 'first ' new '57 I found that Champion J12Y extended tip plugs worked the best.Autolite had the first extended tip plugs in 1955.ACs didn't come out till much later......An engine that fouls plugs (when driving) has a problem (if the plug is of the correct heat range).If it gas fouls-black-dry-sooty-too much gas.If oily, oil is getting into combustion chamber-most common on small blocks due too the over abundence of oil to the rocker arms.Good valve seals and guides are needed.Oil coming past the rings seldom fouls plugs.A hotter plug will foul less but won't "repair" the problem.A AC 46 could be used- but an extended plug may oil foul sooner as it extends farther into the combusyion chamber-at least this has been my experiance.
Execution time: 0.254 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:55 PM
