Username Post: 61 gas line tunnel help        (Topic#351556)
61ohboy
61ohboy
Loc: Tennessee
Reg: 04-12-14
06-14-18 10:47 AM - Post#2736959
I'm going to run a new gas line on my '61. It has a 5/16 right now and I'm going to replace with 3/8 line and want to run it through the drive shaft tunnel.
I wallered under the car to check out the holes and I see two holes on the passenger side of the tunnel. Two holes on the back and two holes on the front. The e-brake cable is running through the bottom holes so that leaves the top hole for the gas line.
The hole looks somewhat small for a grommet and 3/8 line. Does the hole have to be enlarged any and if not, is there a specific size or "special" grommet that must be used? Or to I buy a grommet assortment and keep trying until I get the right size?
I had the thought of slipping a piece of hose over the line and let it be a wanna-be grommet...
I have the steel gas lines I got from Paul. Thanks Paul! And Paul mercifully labeled the sections for me and saved me at least two days trying to figure out which one goes where
So the middle section of gas line is the first one I'm going to put in then I will work on the rear section when I swap the tank. Then I'll see about fighting with the front section...
pvs409
pvs409
Loc: Sergeant Bluff, Iowa
Reg: 01-10-05
06-14-18 01:19 PM - Post#2736969
    In response to 61ohboy
there are specific grommets sold for the 3/8 gas line that slide onto the gas line.The factory holes in the frame are not changed they fit the gas line with the grommets.
When installing the line with the grommets they can get pushed out of the frame by the gas line (hold them in place -use glass cleaner to make the gas line slide easier in the grommets).
If you need pictures of the gas line and grommets I can post some.
here is the part number for description from Show Cars
Part # 1083 -- 58-64 Gas line frame grommets, 2 piece set... Set - $4.79
I could not get the link to work for this part number.
Paul
57 BelairHT 283/270hp 4 spd
62 ImpHT 327/300 4 spd
62 Imp CV SS 327/300HP 700R4
62 ImpHT SS 409/482 stroker 4 spd
62 Imp SS 409 - 5 spd Convertible under frameoff
Web http://paulstensland.com/
61ohboy
61ohboy
Loc: Tennessee
Reg: 04-12-14
06-14-18 01:56 PM - Post#2736972
    In response to pvs409
Hi Paul,
I guess it would be you when I saw a reply. Thank you again for all the help and advice with this project. I still have the pictures you sent last year or more I'm pretty sure. If I can't find them I will give you a shout. I'm off to contact Show Cars now and order the grommets. They looked substantial in their picture. Going to order a spare set too!
thanks again...Dennis
junky
Loc: Northeast CT
Reg: 06-27-10
06-14-18 07:24 PM - Post#2736991
I recently had to replace the bushings on my Corvair stabilizer shaft, and it has two 90 degree bends that the bushings had to go past. I put some silicone oil on the inside of the bushings, and they went past those turn without any problems. I highly recommend silicone oil whenever you need to install any bushing that have a tendency to be problematic. My bottle came with a Cannon copier many years ago, however, it is still available on eBay. A little pricey, but a bottle will last you a few lifetimes, so you can share it with your friends.
ragtp66
ragtp66
Reg: 12-09-07
06-19-18 08:03 PM - Post#2737610
    In response to junky
Junky,
I am in the swimming pool business this stuff will work real well and its cheap. https://sunplay.com/products/pentair-sili cone-lubr...
Toys:
1987 Sea Ray Pachanga 22
DonSSDD
DonSSDD
Loc: Nova Scotia, Canada
Reg: 08-21-01
06-20-18 03:03 AM - Post#2737636
    In response to ragtp66
GM may still sell a silicone lubricant, used in the window slides for tight glass. It has a small brush on the end.
Member #2194
Execution time: 0.366 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:06 AM
