Username Post: 235 cam gear type        (Topic#351547)
z28summit
Reg: 06-11-14
06-13-18 01:24 PM - Post#2736845
Who here is running a fiber gear? I was told to use one as they run quieter.
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
06-13-18 05:19 PM - Post#2736878
    In response to z28summit
Hi Z28, The fiber gear was used in passenger cars and the metal one in trucks.
Fiber is quieter, metal is more durable.
They are interchangeable so it is a matter of preference.
If I was going to use a more aggressive cam or stronger valve springs I would tend to the metal one.
Cheers Kiwi
wbeaton
wbeaton
Loc: Hamilton, ON
Reg: 03-07-14
06-13-18 06:12 PM - Post#2736885
    In response to Bel Air kiwi
Having blown a fibre gear I’d suggest getting an aluminium gear.
1951 Chevy Styleline Deluxe 2 Door Sedan
1954 235 with Isky Cam, Shaved Head
Dual Carter YF 787S Carbs on Offenhauser Intake
Split Manifold Dual Exhaust
3 Speed with 3.55 Differential
12V Conversion with Alternator
Pertronix Ignition
z28summit
Reg: 06-11-14
06-13-18 06:16 PM - Post#2736887
    In response to wbeaton
I have a hyd bulldog cam with stock valve train
06-13-18 06:23 PM - Post#2736889
The fiber gear will eventually fail even with the mildest stock cam. I always install an aluminum gear in any engine I have apart for any reason. The noise difference is barely noticeable.
z28summit
Reg: 06-11-14
06-13-18 08:14 PM - Post#2736903
Okay thanks. I'll pull the old one off the stock cam and put it on
Execution time: 0.631 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:56 AM
