Username Post: vibration        (Topic#351544)
frstcar
Reg: 08-07-17
06-12-18 07:44 PM - Post#2736777
Recently installed Tremec tko500 in my 63 409. Have now developed a bad vibration starting at 1800 RPMs. Will do it whether on the road or sitting still with clutch released or depressed. Feel it worse in the seat of your pants. Have had tranny out 3 times, can't see anything, no interference with the floor pan. Had driveline shortened, balanced, and installed urethane carrier bearing. Any ideas?????
Edited by frstcar on 06-12-18 09:31 PM. Reason for edit: No reason given.
Tri5man
Tri5man
Loc: Possums Crotch, KY
Reg: 06-26-07
06-13-18 12:50 AM - Post#2736797
    In response to frstcar
First off you need a slip joint on your driveshaft if you using a urethane carrier bearing support due to it rigidity. Do you have one?
I wouldn't suspect thats the cause of your vibration as you have it moving and stopped, clutch in or out. Sounds like it could be engine related. I had a wierd vibration once that turned out to be water pump bearings.
Gary
55Brodie
55Brodie
Loc: Little River, SC
Reg: 12-26-15
06-13-18 03:05 AM - Post#2736801
Pilot bearing? Clutch assembly imbalance?
frstcar
Reg: 08-07-17
06-13-18 05:46 AM - Post#2736810
    In response to 55Brodie
Has new pilot bearing and clutch has been balanced
YOUNG57
Loc: Tennessee
Reg: 12-06-10
06-13-18 08:00 AM - Post#2736819
With the clutch pedal depressed the transmission, drive shaft, carrier bearing and pilot bearing are disengaged (out of play). Vibration has to be forward of transmission.
frstcar
Reg: 08-07-17
06-13-18 11:23 AM - Post#2736838
    In response to YOUNG57
My thinking also.
Tri5man
Tri5man
Reg: 06-26-07
06-13-18 04:56 PM - Post#2736874
I'd start eliminating engine accessories by disconnecting belts.
junky
Loc: Northeast CT
Reg: 06-27-10
06-13-18 08:45 PM - Post#2736914
Have you checked the harmonic balancer? It has a hash mark that lines up with the top dead mark on the outer balancer. When they fail, you will see this mark move out of alignment, and the outer ring slips on the rubber separating the inner and outer parts of the balancer.
Chevrobert
Loc: Braintree, Ma. USA
Reg: 06-14-08
06-14-18 03:19 PM - Post#2736976
Nobody's mentioned it so....,
Have you checked your
transmission cross member
motor mounts,
exhaust and hangers etc?
Sometimes things happen at coincidental moments
AND
have nothing to do with
the new addition.
Bob
'64 Impala SS
'77 Pontiac Ventura SJ
'85 Lincoln Town Car
Ain't to proud to think out loud.
Execution time: 1.567 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:04 AM
