Username Post: 1985 Silverado k30 w/454 eng a/c type?        (Topic#351534)
cw41
Reg: 09-07-04
06-12-18 05:05 AM - Post#2736685
I'm rebuilding the entire a/c system on my 85 silv K30 454 engine. Does it use the a-6 long or the r-4 radial compressor? I cannot find info other than it could come either way? I have all the compressor brackets for the A-6 and I see that a new style aluminum version is out, is it any good? the older style I had nothing but troubles with. I have R12 and 134a..
thanks for your time
chuck
Senior Chevytalk Moderator
06-16-18 01:37 PM - Post#2737186
    In response to cw41
Can you fit a Sanden SD7HD? It’s a bolt on with brackets. I replaced an R4 with an SD7HD. R134 uses a cross flow condenser. R12 uses tubes that wrap around. Match the components.
Edited by gchemist on 06-16-18 01:38 PM. Reason for edit: No reason given.
Execution time: 1.532 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:55 AM
