Username Post: Bolt-on front disc conversion for '53 Chevy please??        (Topic#351533)
1953 Chevy 210 4-dr
Reg: 06-11-18
06-12-18 04:21 AM - Post#2736682
Can anybody please recommend a supplier for a complete and easy to install bolt-on disc brake kit for the front of a '53 Chevy 210 4-door with stock suspension & hubs.
Sheldon Y.
Loc: Waltham, Massachusetts
Reg: 10-29-16
06-12-18 04:40 AM - Post#2736683
    In response to 1953 Chevy 210 4-dr
POL, for $332., when I did mine.
Very straight forward, additional shims needed for my '49. The Kit works for 49-54.
I would also highly recommend the Under-Floor Power Brake Booster from ABS Brakes.
Again, very easy install, and now one of the best braking vehicles I own! (Stock Huck Brakes still on the rear).
'49 Styleline Deluxe Build@
https://www.jalopyjournal.com/forum/threads/49-sty...
http://www.frankenrodz.com/frankenstyle.html
1953 Chevy 210 4-dr
Reg: 06-11-18
06-12-18 06:22 AM - Post#2736689
    In response to Sheldon Y.
Thanks for this.
I had to look up what POL stood for first LOL.
But I found it easy enough on the internet.
I have emailed them as the spec on their website says their kit is not compatible with a manual transmission car, mine is manual unfortunately.
Looks nice however. $699 including the Booster.
Lets see what they come back with.
06-12-18 07:15 AM - Post#2736700
Looks like they have a good looking P.S. pump bracket also.
P.S. Pump Bracket for 235
Dean50
Dean50
Loc: Detroit area
Reg: 01-02-07
06-12-18 08:37 AM - Post#2736706
I used Engineered Components on my stick shift car and also added double chambered MC to the stock under floor MC with valves. Pretty easy jobs.
http://ecihotrodbrakes.com/catalog.html
Dean50
tommy49
tommy49
Loc: Kaleva, Michigan
Reg: 09-28-12
06-12-18 02:11 PM - Post#2736736
I have the POL kit. The only issue I had was having to drop the outer tie rod to put the lower caliper bracket bolts in. I also have a Walton Fab firewall brake pedal/ booster kit.
Attachment: 49_front_disc_brake__3_.JPG (159.76 KB) 1 View(s)
Attachment: 49_front_disc_brake__4_.JPG (156.57 KB) 1 View(s)
Tommy
49 Deluxe Sport Coupe, 55 235, 700r4, Blazer rear axle, 4 wheel power disc brakes.
Sethmark
Loc: Statesboro, GA
Reg: 05-04-16
06-12-18 02:59 PM - Post#2736741
    In response to tommy49
I’m running the ECI kit as well and have put almost 1300 miles on it since Thursday. I have no complaints.
Sheldon Y.
Reg: 10-29-16
06-12-18 04:26 PM - Post#2736747
My car is a Stock Manual Trans!
Sir X Loin
Sir X Loin
Loc: Naples, Maine
Reg: 04-26-12
06-13-18 04:43 AM - Post#2736806
I have the Performance OnLine front disk kit too. I did have to send two of the passenger side brackets back. The weld on tab was out of location. The fix would have been easy, but I wanted it right after paying the money for the kit. upon getting a third that was messed up, I just fixed the bracket as it was pretty minor. I assume my situation was rare and they were easy to deal with.
1957 Chevy Pickup 1998 -2012 *sold
1951 Chevy Styleline Deluxe
06-13-18 03:02 PM - Post#2736858
C of the 40s has a dual MC mounting bracket for a manual trans which lets you keep your stock brake and clutch pedals.
https://www.chevsofthe40s.com/detail/31586/Chevrol...
If you are wanting a firewall mount MC, Wilwood has a hanging two pedal assembly, but that may require converting to hydraulic clutch linkage unless you want to try cobbling Z-bar mounting brackets. I personally think staying with stock pedals is a lot less hassle, but it's your build, so follow your heart.
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
06-13-18 04:56 PM - Post#2736875
Hi Guys, I agree with Ray on this, If you aren't building a fast four wheel disc brake car a small underfloor booster will just do. Moving pedals is a big job.
The other thing to consider is if you are always going to stay drum rear, be it Huck or Bendix then you only really need boost on the front brakes to get the pressure necessary to get the most from your discs.
To do this you install your dual master with the stock Chevy size bore. The rears work just as they always did but you put a remote inline booster in the front half only. This avoids upsetting the rear brakes with too much line pressure from a boosted master. Although the little boosters you can fit underfloor are not usually capable of this.
The inline boosters are able to be mounted under the dash, in the engine bay, even in the guard if you put an inlet filter on them. They are a bit dearer but they were a factory solution to disc/drum pressure variables. They don't require a proportioning valve that the aftermarket is so fond of.
Also remember the old single master had an internal RLP valve and so new under floors need them also. 10 psi for the drum side and 2 psi for the disc end.
Just remember you are making a brake system that needs to be balanced and appropriate to the vehicles potential. Piecemeal systems can be very dangerous.
Cheers Kiwi
Attachment: VH44_Underdash.jpg (90.87 KB) 1 View(s)
Attachment: VH44_Chinese_PBR.jpg (99 KB) 1 View(s)
Edited by Bel Air kiwi on 06-13-18 05:09 PM. Reason for edit: No reason given.
06-14-18 07:58 AM - Post#2736939
    In response to Bel Air kiwi
Curiosity here, if the oe manufacturers have used some kind of prop/combo valve for years, why do you believe our disc brake conversions do not require one?
Sir X Loin
Sir X Loin
Loc: Naples, Maine
Reg: 04-26-12
06-15-18 08:51 AM - Post#2737032
I put a Residual inline valve in my front lines to keep the calipers full of fluid. My MC is under the floor, if its on the firewall, you wouldn't need one. I don't use a proportion valve and mine stops mint. Its easy to overthink this stuff. try it and see.
tommy49
tommy49
Reg: 09-28-12
06-16-18 07:34 AM - Post#2737154
    In response to Sir X Loin
I put an adjustable bias valve in for the rear because, with the the 4 wheel power disc, I have no idea how it's going stop.
Attachment: 49_mc-booster-prop_valve.JPG (158.04 KB) 2 View(s)
Tommy
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
06-21-18 10:57 PM - Post#2737880
Hi Tommy, Smart move, that makes your front rear bias tuneable. We have performance criteria we have to meet which involves physical repeat testing on modified vehicles.
I always went this way with one-off work as the customer would go ballistic if the tester wanted a balance change and you had to replace the rear wheel cylinders with a different size to comply.
Expensive waste of parts and labour.
You could use the entire brake system from a donor car, front discs, master, booster and matched drum rears, but if you had a significantly different overall front to rear wheel diameter it may not comply.
Simple turn on the knob and you can dial that balance back in. Everybody is happy.
Plus the testers really love to tweak the setting just to show you they are in charge. A cheap way to massage their ego and get them on board.
Cheers Kiwi
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
06-21-18 11:13 PM - Post#2737884
Hi Shepard, The OE combination vales are one of at least three different ways you can address this issue of the different pressures used for disc v drum systems.
In factory systems, these valves are exactly matched to the vehicle parameters. Their values are fixed and they are not universal.
You could boost only the front half and then the rears are as built.
You can reduce the rear wheel cylinder diameter to match the boosted line pressure. (Note this is an area/pressure calculation.
We do this down under on the 9" ford diffs by simply removing the US backing plate and fitting the Aussie Falcon setup.
The late Aussie Falcon was a matched OE system, plus the GM equivalent master has the same design and bore as the Ford and essentially they are just left and right-hand outlet versions of the same master.
You can also put the Holden callipers on the Ford Disc, for Ford stud pattern, or Holden callipers on Chevy for GM pattern.
I recommend you put in an adjustable proportioning valve so that you can adjust your bias front to rear to get it right.
Cheers Kiwi
Execution time: 0.339 seconds.   Total Queries: 19   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:03 AM
