Username Post: Carb tuning question.        (Topic#351532)
2D51STYDLX
2D51STYDLX
Loc: So. Prairie Washington
Reg: 03-03-11
06-11-18 11:30 PM - Post#2736673
Has anybody ever drilled a hole in the exhaust system, welded in a fitting for a O2 sensor to set the carb ? You could always remove it and install a plug. Doable, practical, what do you think ?
Roger
1951 2 door Deluxe Bone stock, well not quite, bucket seats.
Broken hearts and dirty windows
Make life difficult to see
Thats why last night and this morning
Always look the same to me
John Prine
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
06-12-18 01:38 AM - Post#2736674
    In response to 2D51STYDLX
Hi Roger, Yes I have one on my carburetted 306W in my 32 Tudor. As the headers were always going to be Ceramic coated I put the bung in before they were done.
It could be used for mixture setting or if vehicle was later converted to EFI. The headers were expensive block huggers that had to be modified to fit better so it was definitely worth doing before they were coated.
I have never tried to grind off that HPC ceramic to weld something but I bet it would be nasty and never look right afterwards.
Mine just has an old sensor as a plug. But I guess you could use a bung. Position is important so do a bit of research.
Cheers Kiwi
Edited by Bel Air kiwi on 06-12-18 01:40 AM. Reason for edit: No reason given.
Execution time: 0.751 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:55 AM
