Username Post: EXTREMELY loud fuel pump        (Topic#351519)
Junkyardwarrior
Loc: Yuma AZ
Reg: 02-25-15
06-11-18 02:23 PM - Post#2736619
I couldn't seem to find anything on this. Just driving around town, not doing anything crazy, my fuel pump is not noticeable over the noise of the truck unless you stand next to the truck. However, after about 185 miles in a straight shot up to phoenix, the pump was just screaming loud. I went through a drive through and all you could hear was the high pitch whine of the pump. When I shut the truck off it sounded horrible. I also noticed what felt like a severe lack of power when I got on the throttle, which happens a lot on I-10 with those no driving morons. The truck has never failed me so far, and I would like to keep it that way, especially with my intentions on moving from az to nc in the next couple months towing my Nova the whole way. Anyone deal with this before? For those that don't know, it's a 99 K2500 7.4 completely stock outside of the lights and the stereo. Even has the stock exhaust.
"8 cylinders of why the f&@% not" - me
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
06-12-18 12:49 PM - Post#2736728
    In response to Junkyardwarrior
Time to change the fuel pump. My personal opinion is it's much easier to slide the bed back than drop the tank. Living in Phoenix, you probably don't even know what rust or seized bolts are. Shouldn't be bad at all for you.
Jeff
Junkyardwarrior
Loc: Yuma AZ
Reg: 02-25-15
06-12-18 01:01 PM - Post#2736732
    In response to bowtie44s
Man, that's on the list of crap I really don't want to do either way. And yeah, hardly any rust. oddly enough there is some on the top by the windshield so that leaks the 3 times a year it rains here but other than that even the front suspension came apart without much complaint. What are the odds that the fuel filter is the culprit?
454cid
454cid
Loc: West Michigan
Reg: 02-18-12
06-12-18 06:13 PM - Post#2736762
I completely removed my box, but I also undercoated the frame at that time, too. I bet sliding it back would work great.
I think the bed bolts are the bolts that I priced at the dealer and found them to be very expensive. I used those plastic push pins that normally hold up hood insulation to pad the box and the frame when I put it back together.
Also, I would recommend buying a new seal and retaining ring for the pump. I don't recall if the AC Delco pump came with the seal or not, but it did not come with the ring. That delayed me in replacing the pump because my original was quite rusty, and I had to wait for it to be ordered, after I had already waited for the pump. You may find that yours is rusty even though you're in AZ since it's on top of the fuel tank, and will collect dirt, which will in turn hold moisture. I filled that area with grease as a rust preventative.
99 K3500 RCLB
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
06-12-18 07:30 PM - Post#2736774
    In response to 454cid
change that pump asap. It likely had a bad connection and the resistance killed the windings in the pump.
Burnt plugs are very common on GMs of this era
Old School GM fan FOREVER
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
06-12-18 08:16 PM - Post#2736782
It took me a minute to figure out what you were talking about, then I remembered some places up north call the bed a box.
Jeff
454cid
454cid
Loc: West Michigan
Reg: 02-18-12
06-12-18 09:51 PM - Post#2736791
Really? I thought that was fairly universal. I guess it's like when I read someone calling there cap something like a "topper".
I sleep in my bed, I haul stuff in the box :-)
99 K3500 RCLB
Junkyardwarrior
Loc: Yuma AZ
Reg: 02-25-15
06-12-18 10:27 PM - Post#2736792
Not gonna lie there is a lot of language that I want to use right now that isn't appropriate for this particular platform... I REALLY don't want to have to replace the pump. But as it is, I would rather not lose the damn thing going up a mountain in west Texas.
454cid
454cid
Loc: West Michigan
Reg: 02-18-12
06-13-18 12:23 AM - Post#2736796
It's not that big of a deal when pulling the box. You don't have to drop the tank, you don't have to siphon gas, you can stand up while connecting hoses and wires. It might take some fiddling to get the fuel lines disconnected. I bought two sets of the tools to disconnect them, and I think I still had to break one of the original connectors on the old pump.
The box is eight bolts, plus you'll need to disconnect your tail lights and fuel filler. I don't remember if I had the bumper off or not... if you leave it on you'll have to lift the box over the bumper. You may want to remove it so save your paint. There were four of us that lifted mine off. When putting the box back on, you might want a person handling the filler hose so it doesn't get caught on the boxside...I tried to have my sister do that. Unfortunately, she had no idea what I was talking about, and it caught the boxside :-(
99 K3500 RCLB
06-13-18 08:21 AM - Post#2736823
I removed the bed on my 92 S10, by lifting it off with my cherry picker. I took it of and put it back on by my self. Think it only had 4 bolts tho.
Junkyardwarrior
Loc: Yuma AZ
Reg: 02-25-15
06-13-18 09:23 AM - Post#2736830
It's not doing the work that gets me. It's paying for the pump with all the other stuff I have to replace on it and my Nova right now before I move. Seems like every issue wants to show up at once, when I need them the least.
06-13-18 10:04 AM - Post#2736834
Your 1999 model uses an all-in-one pump contraption with the sending unit in a plastic bucket. I call it the plastic trash can pump. Your best bet is to stick to good names like AC Delco or Delphi; ignore the rest, especially Airtex.
Keep in mind it's easy to spec the wrong pump for this truck being a 1999 classic model; you may be better off using 1998 as your model year when looking up parts. The 1999 redesign truck uses a completely different setup.
Pay attention to the code letters on top of your existing pump; you'll need it to buy the correct new pump.
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
06-13-18 01:55 PM - Post#2736850
    In response to someotherguy
Id just point out that in most O.E.M, in the fuel tank electric fuel pumps are cooled by sloshing fuel, if you let the tank regularly get below about 1/4 full the pump spends more time not being cooled to ideal levels and statistically it tends to wear out a bit faster, Id also point out that adding several ounces of Marvel Mystery Oil to each fill-up seems to help reduce wear issues and varnish and rust problems inside the fuel tank
look at the pictures in this thread carefully, similar too this,
the electric fuel pump is located in the lower 1/4 of the tank too insure its cooled by sloshing fuel
Edited by grumpyvette on 06-13-18 02:18 PM. Reason for edit: No reason given.
454cid
454cid
Loc: West Michigan
Reg: 02-18-12
06-13-18 05:00 PM - Post#2736876
What's your feeling on this? Only $38 from Rockauto. It's listed for my 99.
Link
99 K3500 RCLB
06-13-18 05:19 PM - Post#2736879
There's a similar offering from AC Delco and I'd buy that before I would ever trust some no-name pump.
I used to recommend the pump-only fix kit for the plastic trash can assembly, because back in the day the assembly was $300! It's half the price now so it only makes sense to go ahead and replace the whole thing while you're in there, so you get a new sender while you're at it. No sense having to drop the tank twice.
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
06-13-18 05:57 PM - Post#2736883
^ I agree with that 100%!
Jeff
454cid
454cid
Loc: West Michigan
Reg: 02-18-12
06-13-18 06:24 PM - Post#2736890
I didn't know AC Delco had one... it's not listed for my truck on Rockauto, that I see. It's possible they just don't have it, Though.
99 K3500 RCLB
Stinky
Loc: Whitewater, CO
Reg: 05-25-01
06-16-18 07:58 AM - Post#2737157
This is $148
https://www.rockauto.com/en/moreinfo.php?pk=148154...
They also have an AC at 138
Carter starts at 108
Something I like about the RA catalog is that you can click on the PN and it will show you the cross over.
Execution time: 0.681 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:57 AM
