Username Post: power steering kits        (Topic#351509)
sanee64
Loc: atlanta ga
Reg: 04-05-18
06-11-18 04:34 AM - Post#2736573
best bang for the buck? i see ccp 500 series box and borgsen (sp)
any pros and cons to either? other brands?
thanks
models916
Loc: Addison, IL
Reg: 05-28-10
06-11-18 05:05 AM - Post#2736576
    In response to sanee64
Check the fit for the radiator.
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
06-11-18 06:57 AM - Post#2736585
As previously mentioned, the Borgerson is smaller than the cpp and on some cars the cpp requires 'notched' radiator.
Also, check the tubular upper control arms (required to get the caster) and a larger front sway bar. And the steering column parts required.
It's not a simple, nor as inexpensive as the vendors make it seem.
Pete
sanee64
Loc: atlanta ga
Reg: 04-05-18
06-11-18 11:13 AM - Post#2736602
    In response to japete92
how do i checked to see if my rad is "notched" not too sure what im looking at/for
its definitely not as inexpensive but i need/want it. somehow now i cant find where i got the borgerson link also
Pete
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
06-11-18 05:41 PM - Post#2736633
Pete
The radiator needs to be 'notched' IF the steering box will interfere with it. Something like this:
https://www.classicindustries.com/product/1963/che...
Notice the 'notch' in the lower left (as looking at the pic).
The Borgeson steering box is 'shorter' than the CPP.
Does that help?
Pete
sanee64
Loc: atlanta ga
Reg: 04-05-18
06-11-18 07:51 PM - Post#2736657
much appreciated!!
Pete
Does that help?
Pete
Execution time: 0.644 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:08 AM
