Username Post: ragjoint replacement        (Topic#351506)
jophes72
Loc: Huntington Beach CA
Reg: 07-19-16
06-10-18 06:44 PM - Post#2736541
Any tips on ragjoint replacement for a 1968 c 10 with manual steering . Seems to be the original. I would love to swap the whole thing ,but its not in budget right now. Thanks Joe .
Edited by jophes72 on 06-10-18 06:45 PM. Reason for edit: No reason given.
bobschevytrucks.com Ecklers
JimKshortstep4x4
Chevytalk Moderator & "14th Year" Silver Supporting Member
JimKshortstep4x4
Loc: Muskegon, MI, USA
06-16-18 05:51 AM - Post#2737141
    In response to jophes72
My experience is mostly on the 69-72 trucks which have the steering sections which collapse. The feature allows enough slack to change the rag joint fairly easy. On your truck, I believe that you have the solid 3/4" shaft which limits getting the shaft out of the way. I believe you have two options: 1) move the column upward or 2) move the steering box downward. There is a 3rd possibility of moving the shaft upward but usually the bearings are stuck on the shaft preventing this.
66 Impala SS, 396, TH 400
69 El Camino, 350, TH 350
Execution time: 0.341 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:19 PM
