Username Post: 64 rear axle bearings        (Topic#351503)
jdss
Reg: 02-20-18
06-10-18 02:49 PM - Post#2736531
Where do I purchase new rear axle bearings for my 64 belair? What parts are needed to complete this job, the bearing with the o-ring, the retainer plate gasket, is there also a seal of some sort or does the o-ring on the bearing control the oil?
junky
Loc: Northeast CT
Reg: 06-27-10
06-10-18 06:53 PM - Post#2736542
    In response to jdss
You should be able to get the bearing at NAPA or any other auto parts store, since they are rather common item still today. There is a paper gasket that goes between the differential housing and the backing plate, that you might or might not want to replace. It is a rather simple project to do, once you have the bearing pressed onto the axle. $26 with free shipping on eBay... Link
jdss
Reg: 02-20-18
06-10-18 07:56 PM - Post#2736547
    In response to junky
Thank you for the reply. What about the o-ring that goes around the bearing? The pictures of the bearings for sale don’t show it. I think the o- ring is the only thing that keeps the gear oil from leaking past the bearing.
06-10-18 08:08 PM - Post#2736549
    In response to jdss
ALLLLLLLLLLLLLLLL replacement 55-64 axle bearings are sealed. ALLLLLLLLLLLLLLLLL replacement 55-64 axle bearings come with the O-ring(s). ALLLLLLLLLLLLLLLLLL replacement 55-64 axle bearings come with a lock ring.
Gaskets for the axle bearing retainer are NOT included, they have to be bought separately.
And here is how to remove/replace a 55-64 axle bearing.
By the way, the part number for 58-64 rear axle bearings is the RW-607 series. Depending on bearing manufacturer, some bearings come with a wide groove/wide O-ring, some come with 2 small grooves/small O-rings, some come with one O-ring, some come with 2 O-rings. They are ALLLLLLLLLLLL interchangeable.
jdss
Reg: 02-20-18
06-11-18 04:46 AM - Post#2736575
Excellent information thank you. I’ll see if my local NAPA has them in stock. If not order on line and play the waiting game again.
jdss
Reg: 02-20-18
06-20-18 06:36 PM - Post#2737725
    In response to jdss
just wanted to thank everyone for the help and information on my axle bearing questions. I got the correct bearing the rw 607 finally, the first bearing they sent was a rw 307. waited for the right part pressed it on and all is good to go, Thank You!
Execution time: 0.886 seconds.   Total Queries: 14   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:04 AM
