Username Post: 69 Caprice 2 Dr Window Regulator        (Topic#351499)
58_Impala_Man
58_Impala_Man
Loc: Central Pennsylvannia
Reg: 07-07-10
06-10-18 11:21 AM - Post#2736517
69 Caprice 2 Dr Window Regulator question, I want to repair the drivers door manual regulator. It has a 7 tooth small gear that is stripped. Large gear is fine. Is this gear used in other GM regulators such as cheaper 4 door models? I found a gear replacement for trucks in the year but it has 6 teeth. Hard to find the a new 2 door regulator and if you do they are quite expensive. I can get 3 rivets and replace the gear if I know what to take it from. Thanks!
1958 Impala 2 Door Hard Top Silver Blue and Snowcrest White
62BillT
62BillT
Loc: Moneta, VA
Reg: 09-24-01
06-10-18 05:17 PM - Post#2736537
    In response to 58_Impala_Man
I would guess that the gears would be the same 2-Dr to 4-Dr, but not real sure.
I may have a good used 2-Dr Regulator available if you decide to go that route.
Bill
Member:
-National Impala Association
58_Impala_Man
58_Impala_Man
Reg: 07-07-10
06-10-18 10:47 PM - Post#2736558
    In response to 62BillT
How much would you want for a good working Driver side door regulator?
62BillT
62BillT
Loc: Moneta, VA
Reg: 09-24-01
06-11-18 01:25 PM - Post#2736615
I'll send you a PM.
Bill
Member:
Execution time: 0.877 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:05 AM
