Username Post: Oil usage        (Topic#351482)
Mike7231
Reg: 06-08-18
06-08-18 04:40 PM - Post#2736346
I have a 1954 belair, with a 235 ci engine, 52,000 actual miles. I have had the head rebuilt, new valve guides, seals, seats, and new intake valves. It was smoking quite a bit when you let off the accelerator. That problem has been solved, smoke gone. Cylinder walls looked good, minimal wear. My problem is oil usage. About a quart every 400 miles, no leaks, no smoking. Plugs are burning white, no fouling...Any Ideas? I am using 10 40 synthetic blend for high mileage engines..
06-08-18 05:10 PM - Post#2736348
    In response to Mike7231
A leak down test will determine ring seal condition, keep in mind this does not check the oil ring efficiency. Make sure your road draft system is working, built up crankcase pressure can cause oil consumption.
06-08-18 09:15 PM - Post#2736367
Are your crankshaft seals leaking? Reason I ask is the synthetic blend--synthetics in older engines and gearboxes have been known to leak, reason being their molecules are more uniform and smaller than regular oil.
Mike7231
Reg: 06-08-18
06-09-18 03:34 AM - Post#2736370
I see no visible oil leaks. I check under the car everytime I pull out of the garage. Front and rear seals do not appear to be leaking. The synthetic blends are supposed to help with seals oil n older engines, keep them pliable, and prevent leakage. One of the reasons I switched to the blend..
2blu52
2blu52
Reg: 03-12-02
06-09-18 05:54 AM - Post#2736374
How do you use the car. Daily, short trips, long drives, city driving, or highway driving. Some information would help. Also I do not know that the new synthetic oil you are using will effect the rope seals used prior to 1955 in these engines. When I was a kid (wow) a car that used no more than a quart of oil in a thousand miles was considered to be in pretty good shape.
THOMAS JEFFERSON
06-09-18 06:19 AM - Post#2736375
    In response to 2blu52
If it ain't leakin, then it's burnin' the stuff, or it's going out the road draft tube.
Mike JW
Mike JW
Loc: Arroyo Grande, CA
Reg: 01-19-06
06-09-18 07:15 AM - Post#2736389
If you have a dual diaphram fuel pump check the diaphram that assist the wipers could be cracked and sucking oil out of the crank case.
2blu52
2blu52
Reg: 03-12-02
06-09-18 08:12 AM - Post#2736392
And if that is happening then the filtered cap on the rocker arm cover needs to be cleaned. A quart in 500 miles of good warmed up engine driving, might now show up on the spark plugs.
THOMAS JEFFERSON
Mike7231
Reg: 06-08-18
06-09-18 10:10 AM - Post#2736401
My wife and I like to take weekend trips in the old car. 200 miles one way maybe. 60 to 65 mph.. Not a daily driver. I hadn't checked the road draft tube. Gonna look a little deeper when we get home from this trip. About 500 miles total this time..1 1/2 qts of oil, 19.5 mpg...
bobt
Loc: colonial heights va
Reg: 06-28-14
06-09-18 01:05 PM - Post#2736421
Fact, The oil is going somewhere. I think that a quart every 400 miles is too much. I'm sure if you were burning it, you would see some smoke. A teaspoon of oil will produce a lot of smoke. Have you checked your dipstick length? You could have a incorrect or shortened dipstick due to loss or breakage and you might be over filling the crankcase and the excess would be pushed out while driving at high rpms. When you park the car after a trip, put a piece of cardboard under the engine and transmission. An engine leak can drip at the transmission after driving at high speeds. Also remember that it is normal for these ol' stovebolts to drip a little.I use about 1/2 quart between oil changes. It is also normal for some drips coming out of the puke tube.
Edited by bobt on 06-09-18 01:14 PM. Reason for edit: No reason given.
2blu52
2blu52
Reg: 03-12-02
06-09-18 01:33 PM - Post#2736424
I am going with a leak some where. the drip pad or pan advice is good. Also if you have not, put the car up in the air and with a good light look along the frame, drive shaft, exhaust pipes etc., to identify a leak location. My 52 had a small drip, it was moving back and blowing off the engine onto the exhaust pipe which left no drips under the car.
THOMAS JEFFERSON
Mike7231
Reg: 06-08-18
06-09-18 04:37 PM - Post#2736441
This particular year didn't have a filterd oil cap. The valve cover has about 4, 1" long vent slots in the valve cover itself. Dipstick is the right dipstick as well. Only a drip or 2 when the car sits in the garage after a trip. Nothing abnormal for these old engines. Will be looking at the road draft tube this week..
2blu52
2blu52
Reg: 03-12-02
06-09-18 04:52 PM - Post#2736443
My apologies, thinking ahead of myself. I had a filtered cap on my 216 to aid in airflow and to clean at least some of it up.
THOMAS JEFFERSON
RAM_51
RAM_51
Loc: Yakima, WA. USA
Reg: 12-28-02
06-09-18 06:51 PM - Post#2736447
If oil is leaking from the car while you are moving, [road draft tube, rear main, etc] it will be flung onto the trunk of the car as it exits from underneath. Check your deck lid for spots of oil. You can actually see these if the car / truck is a little dirty as the oil will be absorbed into the dusty surface and be more visible.
1951 Fleetline
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
06-09-18 07:08 PM - Post#2736448
    In response to RAM_51
400 miles to a quart is normal for that engine. Chevrolet used rather weak rings and 1953 Power Glides and all 1954 engines would use that much oil. In 1954 an engine would normally use a quart in 1000 mils or so when new.
Oil or additives will prevent modern seals from hardining but not "repair" neoprene seals that are 50 years old. Your rear main seal is graffited rope.
In 1954 it was normal to replace rings in many engines by 50,000 miles.
Edited by Gene_Schneider on 06-09-18 07:09 PM. Reason for edit: No reason given.
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
06-10-18 10:51 PM - Post#2736559
    In response to Gene_Schneider
Hi Guys, to add to what Gene said, this is not the era of clean low oil consumption engines. Also bear in mind that if it just drips a couple of spots at standstill that may well increase when driving as the pressures are up.
A single drip every 400 yards soon mounts up to quite a lot of oil.
If it isn't making a mess on your drive and it runs nice, jut top it up as required.
But just keep monitoring it as you have been doing. Modern cars are a complete paradigm shift from the correct way to maintain and drive classic cars. It ain't no appliance, she's a real car.
Cheers kiwi
Mike7231
Reg: 06-08-18
06-15-18 03:20 PM - Post#2737068
    In response to Bel Air kiwi
Thanks for all the replies! I have had several old chevys with the 235 engines, but that was back in my teens, almost 40 years ago, when I could barely afford to keep them going as daily drivers. I picked up this 54 about 3 months ago, in great condition, just needs a little attention that I was expecting, and can now afford to give. I have found low compression, and probably going to do a complete rebuild in a few weeks. I have always believed in boring, at least .010, just to get all cylinders at the same bore. Any suggestion otherwise? Or other advice??
2blu52
2blu52
Reg: 03-12-02
06-15-18 03:31 PM - Post#2737070
If the machine shop is going to assemble the engine be sure that they are familiar with "old stuff".
THOMAS JEFFERSON
Mike7231
Reg: 06-08-18
06-15-18 04:17 PM - Post#2737074
I will be doing the rebuild, and I have a machine shop that knows older vehicles, and does great machine work. As I said, I've had several of these engines, and have rebuilt a few, as well as small block chevy engines. Just always looking to learn something....
Execution time: 1.047 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:53 AM
