Username Post: 68 Impala rear side markers        (Topic#351443)
skinz66
Reg: 11-13-13
06-05-18 07:59 PM - Post#2736092
Ive noticed on 68 impala rear side markers some have been mounted with mouting screw on bottom and some with screw on top mine do not have a right or left marking ..what is the factory correct way to mount?
68SS427
Loc: Connecticut
Reg: 12-01-07
06-06-18 05:28 PM - Post#2736179
    In response to skinz66
Definitely screw on the bottom. There is no room to easily get a socket wrench on the stud that low next to the trunk drop-off inside. I have noticed a few that were installed wrong over the years. My PET Peeve is guys who install the front header emblem upside down, which I see quite often. Don S
Don S.
1968 SS427 x 4
1968 Impala L-72
1969 Chevelle SS396
Edited by 68SS427 on 06-19-18 06:29 PM. Reason for edit: No reason given.
skinz66
Reg: 11-13-13
06-19-18 10:38 AM - Post#2737534
    In response to 68SS427
Thank you for the help.. i thought that was correct but not 100 sure.. as for the header panel emblem ive never noticed that.. the "V" should face up correct?
68SS427
Loc: Connecticut
Reg: 12-01-07
06-19-18 06:27 PM - Post#2737594
To me, it is so obvious when it's upside down. The bowtie points down toward the ground instead of straight out. So the thin side is the top and the thicker is the bottom.
Don S.
1968 SS427 x 4
1968 Impala L-72
1969 Chevelle SS396
skinz66
Reg: 11-13-13
06-19-18 09:00 PM - Post#2737618
Yes sir it is very clear and obvious..thank u for the info
Execution time: 0.451 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:08 AM
