Username Post: reverse lights        (Topic#351423)
Wooden_Nickel
Loc: Minnesota
Reg: 06-03-18
06-04-18 10:15 AM - Post#2735892
So my 53 chevy 210, 3 on the tree, never had reverse lights from what I can tell, both had a plastic plugs in them. I've seen a couple of different kinds of switches, any suggestions? Where to buy it?
First post many more to come
06-04-18 10:24 AM - Post#2735896
    In response to Wooden_Nickel
Welcome to ChevyTalk. Do you have the service manual for your car? They are invaluable.
06-04-18 08:30 PM - Post#2735962
Welcome to CT. Tell us about your car, and post some pictures if you are able. Ditto on getting a Shop Manual.
Wooden_Nickel
Loc: Minnesota
Reg: 06-03-18
06-04-18 09:56 PM - Post#2735971
yes I do
Wooden_Nickel
Loc: Minnesota
Reg: 06-03-18
06-04-18 10:06 PM - Post#2735973
It needs everything, I want to restore it, more bondo on the the top of the headlights including holding the right bucket in place yhen metal and the rear end it 60% bondo. Its going to be a couple of years but I will get there. Finally got it started amd running, took a mechanic but its running. Just redid all the wiring headlights, break lights and turn signals work now. New oil and anti-freeze going in on Wed for transmission and rear differential fluid. Mice lived in the roof and back window panel so probably all the interior also. the floor in front is gone, plate on drivers seems solid but passenger is soft. Guy from local restoration place coming on Thursday or Friday to give it a once over. I don't mind doing the mechanical but welding is going to be professionally done.
Wooden_Nickel
Loc: Minnesota
Reg: 06-03-18
06-04-18 10:09 PM - Post#2735974
Did find fenders in really good condition one small rust through spot but the rest solid and much better then mine. It came with all but 2 pieces of chrome which i found the windshield wiper already just need the front left grill guard but some of it is in bad shape will probably be cheaper to just replace then fix
Wooden_Nickel
Loc: Minnesota
Reg: 06-03-18
06-04-18 10:19 PM - Post#2735975
except the temp guage the original guages worked found a guy oin georgia that rebuilds them but 3 months to do it so this winter I will send them off
pics here til I get a membership
1953 Chevy 210 2 https://imgur.com/gallery/l1QXIKW
06-05-18 05:39 PM - Post#2736076
Beware of mice droppings. Wear the correct mask when cleaning.
http://www.southernnevadahealthdistr ict.org/health...
2D51STYDLX
2D51STYDLX
Loc: So. Prairie Washington
Reg: 03-03-11
06-05-18 10:41 PM - Post#2736109
I have always wondered how long the droppings remain active with the virus ?
Roger
1951 2 door Deluxe Bone stock, well not quite, bucket seats.
Broken hearts and dirty windows
Make life difficult to see
Thats why last night and this morning
Always look the same to me
John Prine
eplantage
Loc: Southern MN
Reg: 03-15-04
06-06-18 04:34 AM - Post#2736123
Good advice. I ended up with a lung infection after pulling the headliner out of my sedan delivery. Thankfully an inhaler with meds cured it. I'd use an actual respirator and not a dust mask.
Age: 63 at the moment
1950 Chevrolet Sedan Delivery
2002 Heritage Springer FLSTSI
1930 Model A Standard Coupe
RAM_51
RAM_51
Loc: Yakima, WA. USA
Reg: 12-28-02
06-06-18 07:01 AM - Post#2736137
You need to get your hands on one of these. It will explain the installation of accessories that were available for the 1953 models...including back-up lights, associated switches and wiring etc.
LINK:
https://www.ebay.com/itm/1953-Chevrolet-Ac cessorie...
1951 Fleetline
Wooden_Nickel
Loc: Minnesota
Reg: 06-03-18
06-06-18 06:11 PM - Post#2736183
    In response to RAM_51
Yes thank you I just have a mechanics manual
Wooden_Nickel
Loc: Minnesota
Reg: 06-03-18
06-06-18 06:12 PM - Post#2736185
    In response to eplantage
Yes I did
RAM_51
RAM_51
Reg: 12-28-02
06-06-18 08:53 PM - Post#2736206
Ebay is a good source for the correct back-up lamp switch...you can shop around there until you find an acceptable price...this is an example of what you're looking for:
LINK:
https://www.ebay.com/itm/1949-54-Chevy-Bac kup-Ligh...
But like I say, you might find a better price.
1951 Fleetline
junky
Loc: Northeast CT
Reg: 06-27-10
06-09-18 07:08 AM - Post#2736387
I would search for a NOS (new old stock) back up light kit. It will have all the small pieces that you will need, along with the proper wiring and instructions. It might be more money than buying just the switch, but in the end, the additional cost will be offset by the ease of installation and convenience.
Also keep your eyes open for parts cars in your location. You might just find a donor car that will have better sheet metal than your car, and you can cut it up for patch panels. You might even get real lucky, and find one that is so good, that your present car will be a great donor car to restore that one with. Never have a closed mind to any upgrade.
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
06-10-18 11:25 PM - Post#2736560
    In response to junky
Hi Wooden Nickel, I would go with what junkie has said. For that model it may be easier to find a good donor shell. Personally I would go dry state like Arizona or California.
I got a good solid cab for My 48 PU from Norcal and I just save the RHD dash and firewall from my rusty lump.
I was doing the same for my four door sedan but got a bit distracted and bought a pimply Belair when I meant to get a good two door shell.
You are wise to know what areas you can't do. And I avoid panel work. I am happy to do chassis fab and mechanical engineering has been my career. I just haven't done much panel and paint or any trimming so I pass that over to someone good and expect to pay.
My Auto Electrical guru is into 70's Mopars and they used an aggressive weld sealer that makes the floor seams rot out badly. But our Panel Guru has refloored one of his cars totally without even disturbing any of the visible body finish color. It is low mileage factory original PUKE green and it now has faultless floors and completely stock trim. From memory there was a little bit of color paint in the trunk and the lower firewall area but the car looks like a complete original honey.
If he didn't rewire the panels guys cars this would not normally be that economical. Three weeks full time all day no other work, plus the sparky helping at nights gives you some idea of the value of the work.
These guys are 100 beer vouchers per hour during the day so you work out how much is saved by starting with a clean solid shell.
I have walked away from some very rare Chevies based on their rust levels. One was a RHD tin woodie which is one of two or three ever made and the other was a coupe ute that was ex Australia.
Cheers Kiwi
Wooden_Nickel
Loc: Minnesota
Reg: 06-03-18
06-12-18 11:28 PM - Post#2736793
    In response to Bel Air kiwi
TY
Wooden_Nickel
Loc: Minnesota
Reg: 06-03-18
06-12-18 11:29 PM - Post#2736794
TY
belairbob50
Loc: OH where rust never sleep...
Reg: 03-17-13
06-13-18 04:40 AM - Post#2736805
The part numbers for the accessory back up lights for 1953-54 are as follows: #986663 for stick and #986664 for power glide. Both are in group 2.697 of the parts book. I just saw one for sale on e-bay and it has a photo of the parts that come with the kit. This photo may be of help to you.
Wooden_Nickel
Loc: Minnesota
Reg: 06-03-18
06-17-18 10:35 AM - Post#2737263
    In response to belairbob50
TY I found one
Execution time: 0.379 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:54 AM
