Username Post: 2009 gmc savana suspension        (Topic#351364)
Exlsrnyc
Reg: 09-29-17
05-31-18 04:50 AM - Post#2735464
Hey guys i own a 2009 gmc savana van 2500 withthe 6.0 vortec but my ride is very stiff and bumpy does anybody know what kind of suspension i can use to make it smoother or better .
Thanks in advance
Lorence
Reg: 05-23-17
05-31-18 05:42 PM - Post#2735530
    In response to Exlsrnyc
You paid a premium for the 2500 part. Do you need the 2500 part?
If yes, you get the bumps.
If no trade it in on a passenger van. You will probably get a newer 1500 version (if they make one) in a straight trade. It dosen't make sense to pay good money to overhaul the suspension and devalue the vehicle.
I have a 2500 Silvarado 4x4. If I want it to ride like a Caddy I just put a ton of weight in the box.
454cid
454cid
Loc: West Michigan
Reg: 02-18-12
05-31-18 10:13 PM - Post#2735543
What kind of load rating are your tires and how much air is in them? A load range E will have a very stiff sidewall. If the van came from the factory with E's it probably specifies a tire pressure, like 80psi, assuming you're carrying heavy loads or towing. I would only run maybe somewhere around 45-55psi. I used to run lower than that on my truck, but found the front tires would wear funny.
99 K3500 RCLB
Execution time: 0.353 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:05 AM
