Username Post: 70 impala has pedal.        (Topic#351310)
Impala_dave
Reg: 07-15-14
05-27-18 12:48 PM - Post#2735073
Hello all so my 70 has the throttle rod setup. And I'd like to change it to a cable. I tried getting a pedal from a chevy truck and cable but theres np flat spot on the firewall to add it properly. Did the 70s come with cable throttle setups?? I've seen a pedal for a 69 camaro that mounts to the trans tunnel like the stock rod setup but it uses a cable. Can I make that work??? I have the bracket for the throttle cable and lockdown cable for a th350. I'm just trying to avoid spending hundreds for something I might be able to fabricate. If someone has a pic of the factory 70 cable setup that would be great as well
Impala_dave
Reg: 07-15-14
05-27-18 02:25 PM - Post#2735082
    In response to Impala_dave
For anyone in the future I have come across this nice set seems to be legit and should mount to stock location so I think this is my best bet
https://www.ss396.com/part/APA-6CBH.html
Execution time: 0.351 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:07 AM
