Username Post: Miles - Kilometre speedo converter to suit 67 impala        (Topic#351296)
Jordie
Loc: Australia
Reg: 10-02-13
05-26-18 09:56 PM - Post#2735004
Hi all,
Does anyone know if there’s such a thing as an adapter that screws into the back of the speedo and then the speedo cable screws into that to make the miles speedo read as kilometres? And if so, where are they found? I know there’s ones for kilometres to miles but I can’t find any for the reverse. Cheers
"14th Year" Platinum Supporting Member & Moderator
05-26-18 10:06 PM - Post#2735005
    In response to Jordie
Nothing is different, just the scale in the speedometer!
Jordie
Loc: Australia
Reg: 10-02-13
05-26-18 10:58 PM - Post#2735014
    In response to 427SS65
So would there be an adapter that changes miles to kilometres?
Jordie
Loc: Australia
Reg: 10-02-13
05-26-18 11:21 PM - Post#2735015
Or is there a smaller rotating gear that can convert it? Any ideas on who’d be best to ask?
Impala65SS
Impala65SS
Loc: Sweden
Reg: 08-23-07
05-27-18 10:02 AM - Post#2735054
There is one variant you mount on the transmission.
In my country, this is one place to get them:
https://www.tamotor.se/butik/hastighetsmatare -till...
It seems this is a source for them in the US - much cheaper too.
https://transmissioncente r.net/product-tag/speedom...
http://www.youtube.com/watch?v=SXn2QVipK2o&a mp;fea...
65_Impala
Reg: 12-29-02
05-30-18 09:08 AM - Post#2735388
The cable rotates 1000 revolutions for every mile driven. So, just re-gear it so it rotates 1000 revolutions for every km driven. Swap the gears in the tail shaft. Google your transmission and calculating the speedometer gears and follow the info to correct it to read 161% higher than it currently does.
If not that, then use a speedometer correction gearbox. Offhand, I don't know a source for a speedometer correction gearbox so you'll have to Google it and see what you find. Ask for one that is a 1:1.61 ratio.
PatwithaRat
Loc: Bardstown, Ky. USA
Reg: 02-22-02
05-30-18 03:12 PM - Post#2735422
What am I missing here? I would think the only thing needed would be the needle backdrop displaying Kmh.
Voted most likely to end up working at a car wash.
BigDogSS
BigDogSS
Loc: SoCal
Reg: 12-21-01
05-30-18 05:16 PM - Post#2735427
    In response to PatwithaRat
It sounds like he wants to retain the MPH-scale on the face, but change the gear/cable/needle to run at KPH.
In essence, 10mph on the face will equal 10kph actual, 20mph=20kph.....100mph=100kph, etc.
Edited by BigDogSS on 05-30-18 05:17 PM. Reason for edit: No reason given.
Jordie
Loc: Australia
Reg: 10-02-13
05-30-18 08:05 PM - Post#2735451
    In response to BigDogSS
That’s correct.
There’s an adapter on the second link above that speeds up the revolutions by 61% and will make the speedo display a kilometre speed rather than a Miles speed.
I’ve purchased one so I will update and tell you all know if it works when I install it.
Thanks all!
55Redneck
Loc: Hedley B.C. Canada eh!
Reg: 06-24-00
05-31-18 06:27 AM - Post#2735474
The down side in doing what you want to do is your odometer will rack up mileage much faster than if you just changed the guage face. 1 mile=1.6 Kilometers. Here in Canada we went metric when I was in my late teens. To this day when seeing speed limit signs in KM's I still convert it to miles in my head, same thing with temperatures.
In memory of Mike McVeigh, the Mad Springwhacker.
PatwithaRat
Reg: 02-22-02
05-31-18 02:03 PM - Post#2735510
That's what I was missing...
05-31-18 10:50 PM - Post#2735545
I missed that too. But why, at 120 on the converted US speedo, you're only traveling 75 mph. Not real fast!
PatwithaRat
Reg: 02-22-02
06-01-18 04:53 AM - Post#2735556
Yep, you would be pretty much pegged by going with the flow on an interstate.
Execution time: 0.36 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:07 AM
