Username Post: 2018 infotainment center(8") touch screen malfunction        (Topic#351279)
moosehorn
Reg: 05-25-18
05-25-18 12:19 PM - Post#2734912
I recently purchased a Silverado Z71-LTZ. I added the 3 camera trailering accessory. When I try to use the touch functions of the infotainment system I have no luck. I tried calibrating but it will not. When I turn on the trailering Cams the camera select option appear on the screen and it takes touch commands. I tried the settings menu under "Display" and the only options I have are "Touch Calibrate" and "Display Off". Is there something I can do to fix it or will have to go to the Dealer(230 miles of road construction away)?
Execution time: 0.571 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:06 AM
