Username Post: V8 455 plans?        (Topic#351196)
ghettosled
Loc: Moorhead, MN
Reg: 03-29-11
05-20-18 08:40 AM - Post#2734417
Does anybody still have a set of the blueprints for fabricating the conversion parts to install an Olds 455 into a Corvair? I think the company was "Mid Engineering". Thanks in advance,Dan
5Larry7
5Larry7
Loc: Dallas, TX
Reg: 05-17-04
06-08-18 12:53 PM - Post#2736328
    In response to ghettosled
FWIW, I built an Olds Toronado powered 66 Corvair a few years back. I no longer own the car. A friend of mine also built an Olds Toro powered Corvair using the Mid Engineering kit. I borrowed the kit from him to look it over and see if I liked it for my project. The ME kit mounts the engine solidly to the sub frame and then the sub frame mounts to the car with rubber mounts. I decided I would rather mount the sub frame solidly to the car and then mount the engine/transaxle to the sub frame using stock mounts. I felt that having the sub frame solidly mounted to the car added a lot of structure to the car to handle the weight of the power train. I used 2 inch square tubing for the sub frame, same as ME did. I actually finished the car and drove it for a short while. I say a short while as I got rear ended getting on the freeway when a car in front of me made an unexpected stop and the car behind me did not make it. My car was squished between two cars. The insurance company totaled it out, but I purchased it back from the insurance company. I eventually sold it to another Corvair enthusiast who did in fact rebuild the car and got back to running again. I do not have any build plans, as I sort of built it as I went along. I probably have some photos of the car but it would take some time to find them. If I were doing at again, I would use some other lighter, smaller engine to mate up to the Toro transaxle, such as a SB Chevy. If you can find a 66 or 67 Toro, they have what is called a switch pitch version of the TH400 trans, (called the TH425 in Toros). The 66 and 67 also have a lower rear end gear than the later ones which I think is beneficial. I mounted the radiator in the front of the car and ran tubing under the Corvair where the old shift mechanism and heater ducts were back to the engine. Anyway good luck ti you embark on this project.
Execution time: 0.381 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:40 AM
