Username Post: Sticking AC Door        (Topic#351137)
go_hercules
Reg: 10-27-16
05-16-18 06:18 PM - Post#2734135
Been doing a few things to my 1990 C1500 HVAC system. Replaced the blend door actuator and blower motor. The last nagging issue is a sticking AC flapper door. This door and the defrost door are linkage driven by the mode door actuator. The actuator and spring loaded linkage works fine. The door itself gets stuck after sitting for long periods or when very hot outside. I am guessing there is a rubber edge gasket on the door that is maybe gummy. When it sticks you can watch the linkage move and after a few seconds the thing comes unstuck and bangs open. After sitting I can manually grab the linkage and put pressure on it to unstick it so I know it is the door and not the linkage or actuator. SO, has anyone got a fix for this? You can't really get to it to spray something in there. Thought about making a limit stop on the door shaft so it couldn't completely shut and get stuck but then I would always have some leakage past that door. What to do?
Gmctrucks
Reg: 03-15-17
05-16-18 06:24 PM - Post#2734137
    In response to go_hercules
What about replacing the foam with some that you put when a house window or door is leaking.
CowboyTrukr
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
05-16-18 08:41 PM - Post#2734148
    In response to Gmctrucks
That’s not a bad idea. The trouble is, the door sits in such a position that the only way to get access to it is to unscrew the dash and rock it back toward the seat just to be able to see it.
Greg
'00 Explorer XLT 4.0 V6 Auto
go_hercules
Reg: 10-27-16
05-16-18 09:07 PM - Post#2734149
    In response to CowboyTrukr
Yeah, I don't think getting inside of it is even an option. What do you think of my thought of just putting a stop that will let it close just shy of completely shut?
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
05-17-18 06:03 AM - Post#2734158
If it doesn't close all the way,the actuator will keep trying to close it until something breaks. It has a position sensor.
Jeff
go_hercules
Reg: 10-27-16
05-17-18 06:36 AM - Post#2734162
    In response to bowtie44s
Actually on the 1990, it can't do damage because the actuator pushes through a spring loaded linkage. The linkage just loads up the spring as the actuator goes full travel. That is why I get the bang when the door finally lets loose. By the way, the reason the linkage pushes through the spring is not to protect or dampen things, it is so ONE actuator can cleverly control three doors simultaneously through linkages.
Execution time: 1.369 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:20 PM
