Username Post: 2010 Camaro Tranny fluid/filter change        (Topic#351134)
bolake
Loc: Northern MN
Reg: 09-05-17
05-16-18 04:03 PM - Post#2734122
Pickup a 2010 Camaro SS,6.2 automatic. Looking at changing fluids . Rear differential seem pretty straight forward process, drain and refill with GM 75/90 and friction modifier. The tranny seems to be quite different. I see GM says not to flush but replace fluid and filter. The procedure I seen of the one drain plug in the bottom that you also use to fill looks tricky. Could a person just drop the pan to replace the filter and then measure exact amount drained and refill that in the plug above on the side.
If your not the lead dog the view never changes
xstuntman
Loc: west Texas
Reg: 04-13-09
05-19-18 05:20 PM - Post#2734370
    In response to bolake
The fill hole if I remember right is on the passengers side capped with a rubber plug. You run a hose up past the motor by the firewall and insert a funnel into the hose, hose into the fill hole.
The center bolt on the pan is the drain plug.
bolake
Loc: Northern MN
Reg: 09-05-17
05-22-18 05:52 AM - Post#2734590
    In response to xstuntman
Execution time: 0.252 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:03 AM
