Username Post: Intermittant electrical problem        (Topic#351131)
mahlmann
mahlmann
Loc: Las Cruces, NM
Reg: 01-20-11
05-16-18 11:05 AM - Post#2734108
I have an intermittent electrical problem with my '69 El Camino SS 396. Car is stock except for Edelbrock intake manifold, carb, cam, MSD distributor, and exhaust pipes. Sometimes when I turn the key, EVERYTHING is dead including dome light, headlights, horn, and starter. Sometimes, everything is OK. And sometimes it starts OK and then dies at really inconvenient times.
I have replaced:
battery
battery cables
ignition switch on steering column
ignition switch connector
I'm looking for suggestions on what to look for/check out and how to isolate what is causing my problem.
Has anyone had a similar problem?
Thanks for any suggestions.
Mike Ahlmann
Las Cruces, NM
'50 Tin Woodies (two) Ramon and Willard
'58 Impala Sport Coupe
'69 El Camino SS-396
'07 Ford F150 to haul parts for above
'16 Ford Explorer 3.5 EcoBoost - Red Rocket
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
05-16-18 07:06 PM - Post#2734142
    In response to mahlmann
Hello.
You have a bad cable or connection.
Where your main 12v goes to the starter inspect it carefully. Was it replaced?
You may also have a bad fusible link that goes from the main cable to the firewall.
Same with the ground. Cable was replaced?
Is ground going to the engine, frame, and fenderwell?
Turn the key on with a few loads, KOEO. then do a wiggle test of the battery cables. Hopefully it will present itself.
I would say whatever it is should be rather obvious
Old School GM fan FOREVER
Edited by rockfangd on 05-16-18 07:10 PM. Reason for edit: No reason given.
