Username Post: Where does Brake Fluid go?        (Topic#351125)
Jack Crain
Loc: Wichita Falls, Texas
Reg: 07-24-11
05-16-18 05:20 AM - Post#2734082
Some time back I did the disk brake mod an my 46 Fleetmaster. Since then, approximately 4 times, I discovered that when I push the brake pedal, it goes to the floor. When I check the master calendar, the reservoir for the disk side is totally empty. So, I fill it up, bleed the brakes, look for leaks, and go off on my merry way. Each time I have NEVER found any leaks or even evidence of a leak. Over the weekend, after refilling and bleeding the system, I took it out for a spin and made sure I used the brakes very often. After about 50 miles, and a hundred brake applications, I crawled underneath to look for leaks. Every millimeter of the brake system was bone dry. Nothing, Nada. The reservoir was right where I left it when I filled it.So, I parked it and came back into town, scratched my head and had a cool drink to think this one out. I can't come up with anything.
Help!
1946 Fleetmaster 4-dr Sedan with '57 235
Fenton Dual Exhaust and Intake
Dual Carter Webbers 2 barrel Carbs
HEI ignition
Front Disk Brake
T-5 Tranny
lofat46
2nd Year Silver Supporting Member
lofat46
Loc: Bloomingdale, IL
Reg: 08-12-13
05-16-18 06:43 AM - Post#2734089
    In response to Jack Crain
I'm going to take a wild guess and say that a caliper piston seal is leaking slowly onto the rotor and the friction between the pads and rotor are evaporating the fluid. Leaking just enough while driving to lower the fluid level but not enough to be visible while stationary.
1946 Chevy Fleetmaster 4-door Street Rod
Jack Crain
Reg: 07-24-11
05-16-18 07:21 AM - Post#2734097
    In response to lofat46
That makes sense. Next time I am at the car, I'll pull the calipers and see if I can find anything.
HEI ignition
Front Disk Brake
T-5 Tranny
05-16-18 01:46 PM - Post#2734114
Or into the booster if so equipped.
Jack Crain
Reg: 07-24-11
05-16-18 06:09 PM - Post#2734134
They are manual, no booster
HEI ignition
Front Disk Brake
T-5 Tranny
55MAS
Loc: North Coast, Ohio
Reg: 12-19-01
05-19-18 03:44 PM - Post#2734366
Your initial post states "reservoir", implying a single reservoir, instead of a dual reservoir with different sized reservoirs, for drum and disc. What kind of master cylinder you you have?
05-19-18 07:19 PM - Post#2734380
    In response to 55MAS
In Jack's write up in the sticky's, he says he used a dual master cylinder.
55MAS
Reg: 12-19-01
05-20-18 07:34 AM - Post#2734412
ok - missed it.
Jack Crain
Reg: 07-24-11
05-21-18 05:00 AM - Post#2734484
If you re read the original post, I believe you will find the above statement in it.
Also, It was a 76 Mustang disk/drum master cylinder
Sorry but I used copy and paste instead of the quote box
HEI ignition
Front Disk Brake
T-5 Tranny
RoadRocker
RoadRocker
Loc: Kentucky.
Reg: 12-13-13
05-21-18 05:21 AM - Post#2734486
Hey Jack, Same thing happened to me after 1 year?? Looked and could not find where it went? Filled disk side up bleed brakes, no leaks anywhere been 6 months now and all is well. Now I check my fluid often. I do not use brakes alot and have always said you only need them when you get there. Where did my fluid GO??
Tom
48 sports coupe
63 C-10 long fleet
17 Tacoma double cab longbed
17 Toyota Rav-4
Been down most all the roads nowhere left to go??
Jack Crain
Reg: 07-24-11
05-21-18 07:37 AM - Post#2734498
    In response to RoadRocker
Hey Tom, how you been?
I most definitely check my reservoir every time before I head out now. Don't need any surprises. All in all, I am glad I did the mod, as long as I keep the brake fluid topped off, a much better braking system.
HEI ignition
Front Disk Brake
T-5 Tranny
Edited by Jack Crain on 05-21-18 02:25 PM. Reason for edit: No reason given.
RoadRocker
RoadRocker
Loc: Kentucky.
Reg: 12-13-13
05-21-18 03:28 PM - Post#2734529
Jack, I am doing well thanks. I did the disk mod for the dual master as i have lost all brakes in older vehicles with single masters, I lived for 35 years in western NY lots of salt rusty lines and dirt roads. I don't have a problem with drum brakes all around had to lock up the hucks once and they stopped great. Disks lock up quick on snow and ice turning to skies and you can't steer. I have had to pull release on GM cars and use park brake to slow and stop going down hill ! That or the ditch. I always set up drums to grab in the rear first much better handling for me. Happy motoring Jack enjoy your ride
Tom
48 sports coupe
63 C-10 long fleet
17 Toyota Rav-4
Execution time: 0.404 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:18 PM
