Username Post: Backfiring from inside engine compartment        (Topic#351123)
Amdms8
Loc: LA
Reg: 03-27-18
05-15-18 08:26 PM - Post#2734067
I recently added new short headers and a cold air intake to my 1995 c1500 5.7L. I drove 350 miles without any issues on the interstate. When I reached town and stopped at lights and such, the engine was barely accelerating and I began to get backfires. What do you think is the culprit?
1995 Chevrolet C-1500 5.7L TBI Extended Cab
Edited by Amdms8 on 05-16-18 04:53 AM. Reason for edit: No reason given.
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
05-16-18 05:38 AM - Post#2734083
    In response to Amdms8
Backfires out of the exhaust or intake?
Jeff
Amdms8
Loc: LA
Reg: 03-27-18
05-16-18 07:07 AM - Post#2734093
    In response to bowtie44s
It comes from under the hood. I'm pretty sure it's from the intake area.
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
05-16-18 09:23 AM - Post#2734106
Make sure you didn't cross a plug wire when you put the headers on. Check for vacuum leaks.
Jeff
Gmctrucks
Reg: 03-15-17
05-16-18 06:27 PM - Post#2734139
Make sure you put on the O2 sensor but to me it sounds like crossed plug wires.
thx1138v2
Reg: 05-01-14
05-16-18 07:03 PM - Post#2734141
Also double check that the distributor hold down clamp is tight.
scrambldcj8
Loc: MA
Reg: 04-06-03
05-16-18 07:19 PM - Post#2734145
    In response to thx1138v2
350 miles w/out issue?
Amdms8
Loc: LA
Reg: 03-27-18
05-18-18 02:32 AM - Post#2734229
    In response to Gmctrucks
I don't recall an o2 sensor attached to the original exhaust manifold at all. I have 2 O2 sensors 1 before and after the cat. I was thinking it was a clogged fuel filter or a bad egr valve. I plan to check the vacuum lines this monday when I get home from work also.
Amdms8
Loc: LA
Reg: 03-27-18
05-18-18 02:33 AM - Post#2734230
    In response to scrambldcj8
Yes. 350 miles without any issues. Shreveport,LA - Lafayette, La
Amdms8
Loc: LA
Reg: 03-27-18
05-21-18 03:44 PM - Post#2734533
Thank you everyone for not answering with your opinion. Was hoping to utilize all of you to minimize the time to find the culprit. I am now 350 miles from home and all parts stores close in an hour.
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
05-21-18 06:37 PM - Post#2734545
What? You are bitching about people not giving you answers? There were several good ones. I did not see ANY feedback from you. What more do you want when you get several likely possibilities and you don't test or look into a single one?
Jeff
scrambldcj8
Loc: MA
Reg: 04-06-03
05-21-18 06:39 PM - Post#2734546
Here's a hint...it's not crossed plug wires censored.
05-21-18 07:52 PM - Post#2734555
I'll never understand why people get angry when they don't get responses, or the responses they expect, on a free-to-use message board consisting of nothing more than what are essentially unpaid staff - a bunch of other vehicle enthusiasts that do a great job of helping others out, when they can.
Amdms8 you may be frustrated at your current situation but you should also take a moment to re-align your perspective and expectations and realize anybody here that helps is doing so out of kindness, not any obligation.
This is probably the single most helpful auto-related site I have ever been on, and I'm on several, but getting help is always a two way street. Provide clear info, be open to suggestions and more questions, be considerate of those that are trying to help diagnose your issue from a distance without benefit of being in person with hands on the vehicle. Good luck with your situation.
beagrizzly
beagrizzly
Loc: south texas
Reg: 08-04-12
05-22-18 07:40 AM - Post#2734603
    In response to someotherguy
Well said, Richard.
I had an opinion, but I think that I'll just keep it to myself now. I get chewed on enough at work. I don't need to get it when I am off, and doing something that I enjoy.
I'm just saying.
Griff
1960 Biscayne (the 6T)
2005 Yukon XL
2007 GMC Sierra Classic 8.1
2009 Silverado
2011 Escalade ESV
Execution time: 0.287 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:51 AM
