Username Post: Jegs High performance bearings        (Topic#351120)
Junkyardwarrior
Loc: Yuma AZ
Reg: 02-25-15
05-15-18 02:38 PM - Post#2734045
So I sparkled my oil with what I'm assuming to be cam bearing (haven't opened her up yet to verify what bearing died, but judging from the oil pressure...) and I'm looking to order a whole new set of bearings. I'm not a wealthy man by any means, so the Jegs bearings look like a phenomenal deal for hi performance bearings. I'm replacing all of them, cam, rod, mains, just to be safe. Anyone use them/ heard horror stories from them before? I would hate to trash my brand new Lunati with bad cam bearings for sure, much less to kill a crank.
"8 cylinders of why the f&@% not" - me
05-15-18 02:58 PM - Post#2734048
    In response to Junkyardwarrior
It would seem that these are rebranded bearings from a regular bearing mfg. See if you can find out the source and look at their reputation.
Junkyardwarrior
Loc: Yuma AZ
Reg: 02-25-15
05-15-18 03:02 PM - Post#2734049
That seems to be the case with most of their products. It's hard to tell from their website though.
05-15-18 03:35 PM - Post#2734050
Call them and ask who the source is. They may tell you. Worst that can happen is you won't find out anything.
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
05-15-18 05:52 PM - Post#2734056
    In response to Rick_L
question?
how can you possibly even know what size and bearing clearance bearings you need until you tear the engine down and inspect the crank journals rods and main bearing and cam bearings
youll also need to verify piston diam, bore condition, lifter bores, cylinder heads, etc.
you can,t even order bearings until you have done a detailed inspection and precise measuring.
never guess or assume, deal in FACT's,
and measure everything, inspect everything!
Edited by grumpyvette on 05-15-18 06:04 PM. Reason for edit: No reason given.
Junkyardwarrior
Loc: Yuma AZ
Reg: 02-25-15
05-15-18 09:02 PM - Post#2734072
    In response to grumpyvette
Whoa whoa, never said I was ordering them right now. Just that I was considering their brand when I do. I want to know these things before I tear down so I can get it back together asap. I got limited time to get her running again before I move across the country. Just some research man. My luck ain't good enough to guess.
IgnitionMan
Reg: 04-15-05
05-16-18 11:52 AM - Post#2734110
If there are any clear pictures of the outside ends of the bearings, where they butt together when installed,you might be able to see what is on them, like the oversize, what level, like "Clevite", and maker, Michigan", etc.
Long shot, but........
Junkyardwarrior
Loc: Yuma AZ
Reg: 02-25-15
05-16-18 01:08 PM - Post#2734113
    In response to IgnitionMan
Unfortunately no such luck on the pictures. Might just try my luck and jump on em.
IgnitionMan
Reg: 04-15-05
05-16-18 02:14 PM - Post#2734116
I take it you have already done so, but, if not, call Jeg's and ask 'em who, what, where, why, the works on 'em. The Jeg's tech guys are usually wide open, full throttle when I ask them questions.
Junkyardwarrior
Loc: Yuma AZ
Reg: 02-25-15
05-16-18 02:32 PM - Post#2734117
Oh no I haven't ordered yet. I still haven't taken the motor out of the car, much less checked any measurements. That's the fun I have planned for the weekend.
IgnitionMan
Reg: 04-15-05
05-16-18 04:28 PM - Post#2734126
I wasn't suggesting ordering bearings, but, simply to call their tech line and ask about them.
Execution time: 0.277 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:58 AM
