Username Post: Help with intermittant electrical problem        (Topic#351118)
mahlmann
mahlmann
Loc: Las Cruces, NM
Reg: 01-20-11
05-15-18 12:56 PM - Post#2734038
I have an intermittent electrical problem with my '69 El Camino SS 396. Car is stock except for Edelbrock intake manifold, carb, cam, MSD distributor, and exhaust pipes. Sometimes when I turn the key, EVERYTHING is dead including dome light, headlights, horn, and starter. Sometimes, everything is OK. And sometimes it starts OK and then dies at really inconvenient times.
I have replaced:
battery
battery cables
ignition switch on steering column
ignition switch connector
I'm looking for suggestions on what to look for/check out and how to isolate what is causing my problem.
Has anyone had a similar problem?
Thanks for any suggestions.
Mike Ahlmann
Las Cruces, NM
'50 Tin Woodies (two) Ramon and Willard
'58 Impala Sport Coupe
'69 El Camino SS-396
'07 Ford F150 to haul parts for above
'16 Ford Explorer 3.5 EcoBoost - Red Rocket
Tri5man
Tri5man
Loc: Possums Crotch, KY
Reg: 06-26-07
05-15-18 01:40 PM - Post#2734043
    In response to mahlmann
Had the same problem with my 62 Impala Station Wagon. The problem was in the firewalll disconnect plugs. I'd check yours for condition and security.
Gary
Techhead
Techhead
Loc: Etobicoke, Canada
Reg: 10-25-05
05-16-18 06:25 AM - Post#2734086
Check all ground's for clean connections at both ends, IE: No paint under the ground cable/strap.
I have heard of someone else that had an electrical gremlin, the culprit was a loose connection at the starter.
Check to make sure all the terminals are tight.
58 Delray in disaray
Bruces 57
Reg: 01-03-07
05-16-18 07:09 AM - Post#2734094
    In response to Techhead
HELLO;
Had some of the same problems.
Does your electrical system have a stud someplace where the battery connects to that and has all the other hot leads connected to it too?
My recent purchase of a 67 Olds had one and come to find out, that piece was broken from over tightening! (bakelite)
Bruce
Edited by Bruces 57 on 05-16-18 07:10 AM. Reason for edit: No reason given.
Execution time: 0.274 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:08 AM
