Username Post: Heaater/AC control unit        (Topic#351115)
william1180
Reg: 05-14-18
05-14-18 08:56 PM - Post#2733997
All the indicators are constantly flashing. The system seems to work accordingly. I tried anothe heater/AC control unit and got the same result. Where should I be looking to find a problem?
junkman104
junkman104
Loc: Murphy N.C.
Reg: 01-25-14
05-15-18 03:48 AM - Post#2734001
    In response to william1180
Clean the contacts on the unit and plug with contact cleaner spray.
william1180
Reg: 05-14-18
05-15-18 08:12 AM - Post#2734024
    In response to junkman104
Good idea! I tried this and no change.
When ignition is turned on all seems normal. A few moments later and the selected position indicators all start to flash. All functions seem to work. Turning the key off and on again shows a normal condition,few moments later abnormal condition.Strange it did this with a replacement unit too.
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
05-15-18 10:34 AM - Post#2734034
If it is the temperature arrows, the actuator is bad.
Jeff
'88 Chevy K3500, aluminum head roller cam 511inĀ³ stroker 10.5:1 compression, 96 NV 4500, 94-98 grille, 305/70-16 (33x12) BF Goodrich KM2s, 91 cluster swap
william1180
Reg: 05-14-18
05-15-18 10:24 PM - Post#2734078
    In response to bowtie44s
Thanks Jeff, I'll check this . Also the direction of air flow does the same thing. I can change both temperature and direction of air flow. Just the arrows on both flashing.Although I hadn't actually checked the airflow movement to verify where it was coming out.I'll check that next.
scrambldcj8
Loc: MA
Reg: 04-06-03
05-16-18 04:03 AM - Post#2734080
Possibly a blend door is not operating/opening FULLY. My 94 K Blazer has been doing the "flash dance" for years when I put it to "Defrost"....it still defrosts the windshield so I just ignore it.
I even have a brand new AC/Heat dash control unit that I do not need....hint hint
william1180
Reg: 05-14-18
05-17-18 09:50 PM - Post#2734224
    In response to scrambldcj8
Thanks for the tip on the blend door activity.I'll be checking that in a couple of days.Some other tips I've received to be checked out also.
Don't need a new unit as I also have a spare now that I ordered last week. It also had the same results. so it's obviously not the control unit.
Execution time: 0.276 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:49 AM
